But why would they edit the image when they can change the html?
http://a.imageshack.us/img163/7199/faket.png
If I had real numbers and put them put I would use a fake screen as people then would disregard them.
In spite of being real.
I assume the 6870 is the card to get ;)
Per-pixel..? Bro, resolution is ratio. More is more... 1920 x 1200 is more than 1920 x 1080. Any benchmark will change it's fov to render @ said resolution, otherwise it would just stretch scenes & be dysfunctional as a benchmark.
More to tessellate, more work to be done. Aren't you dismissing the obvious?
I said physical scale. So, i can say to the model, i want a polygon every mm of the model (that implies working the model up to scale). So... if the model will be distant then i use some low tessellation on it, if the model is close to the camera than i will input a higher value to get more detail.
Still, even then resolution plays a huge role into the render time since the actual displacement is done through the shader, through a black and white map (exactly how you do it in DX11 as well). So, more pixels = more space to shade/displace.
Remember, tessellation means you divide the polygons of the model into more polygons.
Displacement means you then use a black and white map on the tessellated model and you displace extra geometry via shader = which means more render time when you increase the resolution. especially when you use higher AA (you have that in CGI as well, you can use low AA or high AA, depending on the scene or desired render time/quality).
Also, shading is done usually at a sub-pixel level, because you use an AA filter for subpixel transitions (better, crisper renders), like Catmull-Rom for example, so as you up the resolution and AA levels, the displacement takes longer to do.
I can go on about this forever, but i think you get the picture. There is a clear distinction between tessellation (done via geometry shader in DX11) and displacement, done after that.
Profit margins. AMD with the current price makes quite a bit of money but what if they could charge about a hundred dollars more across the line. They would be making a crap load more, probably a hundred million more with the number of cards they already sold.
With the rates that these cards are selling out, AMD might be thinking they released the 5xxx series at too low of a price and they can not outright raise the price themselves too much(the most they could get away with was the 20 dollar raise they did).
What they could do is release a somewhat modified card which has better performance that atleast matches the competition and somewhat beat's it and increase the price of the line 100 dollars(and these cards likely cost the same to produce considering improved yields). Not taking huge design risk allows them to develop the card way faster which is probably the most important thing considering the time between now and 28nm is when NV will have nothing to respond with in the high end market beside the gtx 490.
By keeping this performance in check and not doing something crazy to this generation: it allows them to make a new product for cheap(low R and D), keep current 5xxx customers happy by not feeling that they were duped into buying a slow early 5xxx and it also prevents these owners from flooding the market with used 5xxx cards which might prevent a new sale of a 6xxx series.
According to steam, close to half the 5xxx cards are the 58xx variants. Thats 8 million cards considering 16 million cards have sold. Both the 5850 and 5870 have prices of 259 and 379 MSRP but have sold for atleast at the beginning at $350 and $450. What if AMD simply refreshed the line with about 20% more performance, released at better quantities so that the card sold at MSRP and they reaped the benefits rather than the retailers who gouged us.
This is what AMD should have done in the first place and I think they realized this.
This quarter, the AMD graphic division made 40 million dollars net which is pathetic considering the extreme monopoly they had. NV had quarters where they made hundreds of millions of dollar during their prime. Just imagine how much difference to this net profit if they charged 100 dollars more, if AMD for example charged 100 dollars more and sold 10 million cards not including the lowend, depending on the deal they had with partners, your looking at atleast 200 million more in your net profits even with R and D, money shared with partners.
Fermi has been such a PR disaster for the consumer because of heat and energy concerns that the rate of the 5870 and 5850 don't seem to be slowing down that much and are still selling out.
They could release a card that just as fast as the gtx 480 add 100 dollars to the 58xx current price and it would still sell if they avoided the energy and heat output of the gtx 480.
They have alot of momentum so people might just buy an AMD card just because it is new and they haven't jumped on the directx 11 fence this generation.
Considering SI was originally design for 32nm and considering how quickly they got this line up together I am thinking this card just from a time perspective has to be way way more cypress than NI, which lead me to believe they might improve performance 20-30 percent but nothing crazy like the fake tesselation score in unigine.
Tajoh, ive been hearing that Cayman was originally designed for 28/32 nm as well.
Thinking about it some more, it makes sense. As GPU's take years to go from design to being finalised, I am sure the architecture after Cypress was designed with 28/32 nm in mind. Its not like the transition from 45 to 32 nm was taking too long so AMD just decided to modify the Cypress core here and there and sell it as Cayman in a few months. Also, the fact that 67xx seem to be modified Cypress cores means that Cypress would be cheaper to manufacture than a dumbed down Cayman cores, which might happen due to the fact that Cayman will be bigger in size compared to Cypress since, again, it was designed for 32nm.
Power consumption apparently seems to have gone up in comparison to Cypress as well. Hmm.
Also, you do need to realise that 67xx are going to replace the 58xx cards. I doubt AMD would price their midrange 67xx cards at current 58xx prices. Hence from what I feel, 68xx will be priced slightly more than 58xx, and 67xx are going to fill up the $150 - $200 market.
Of course I might be wrong :shrug:
are you familiar with a z-buffer? triangles directly affect rasterization and z-buffer performance. because of the way z-buffer algorithms are optimized(hierarchy, with quadtrees, coarse grained culling) tiny triangles hurt efficiency which tessellation creates.
i am saying that the # of triangles and their properties are directly related to rendering speed.
why do you guys continue to discuss semantics though?
the original point was that one score was 1920x1080 and the other 1920x1200 and that they were not comparable... to which i and others said, the difference in unigine between those two resolutions should be tiny and the scores would be somewhat comparable...
and they are... somebody compared 1080 vs 1200 and the performance is almost the same...
Thx for the lengthy response, appreciated the thought & gesture. :)
Regarding your opinion, it has merit of its own, but i dunno man, i don't think ATi will make a whole family refresh just to keep profit margin by creating a bigger & more power demanding chip at the top and just relegating the old chips downward + renaming them nVidia's style. Remember RV 790 ? A new SKU with relative minimal R&D to matchup better with competitor's better SKU, it still kept the same family nomenclature. Only time will tell the truth (will be unveiled in the near future i presume) & speculation is fun, like what Saaya said earlier. :D
About the leak numbers, i think those are quite possible, but for me personally, the Vantage & Crysis score seems more believable & more probable. Why ? Because i do have a strong feeling regarding the added efficiency of the rumored, new 4D SP array design, applied on Cayman with 1920 SP (480*4). Regarding tesselation, while the smart money will put on a stand that ATi should have improved its current mArch relative dismal geometry & tesselation capability, i really don't have a clue on how they could achieve that.
I could see if AMD doesn't update the 5770 them still keeping the 6770 range at the low price they are at. However, if it performs 25% better, I could see the 6770 being knocked up 50 dollars. If the 6770 performs like a 5830 or a gtx 460, it can totally get away with a price tag of 179.99 and the 6750 being 150. AMD can get away with such pricing because they have the momentum right now and Nvidia's low range products are looking mediocre.
If the 5xxx series is off the market, the consumer will be basically forced to buy AMD's line if they want something new at all or buy NVidia's slightly cheaper but worse performing line with higher power and heat.
The later they don't mind because they allow them to be reestablished as the premium brand in addition it allows their competitor to make some money just not that much.
Making money is the number one priority of a company, and getting something as quick to the market ASAP when the competition is vulnerable is the most important thing during that time. Nvidia is going to jump on 28nm ASAP when it comes out and AMD going to need a line at 28nm at that time too. This is likely going to be late 2nd quarter or early in quarter 3 of next year.
I cannot see AMD spending a full R and D budget and more to rush this product on a product that's going to only have a 9 month life cycle(which will be likely the shortest lifecycle ever for a lineup). They really don't need to blitz NV at this point. They are selling like crazy as is, and by keeping performance in check, it gives more incentive for people to upgrade when the 7xxx generation happens. Considering that this chip has to be bigger than the chips as is, to perform better, its not the place to take risks as we have seen with the TSMC 40nm. Its better to be safe so you can have predictable power outcomes.
I could see Nvidia still selling during this period with a 384 shader part at 249, gtx 480 at $399 and a gtx 490 at a price of 499.
Too much performance really is going to lead to gouging which really doesn't help AMD as a brand to profit as seen from their last quarterly statement. At this point timing is more important. The longer AMD can get away with big margins, the more money they will make.
that's almost never done and for good reasons. also a gf100 based on 28nm could be easily 40% faster with relatively little effort.
R&D is a fixed expense. it doesnt change much. but really it's not a quick paced game like you think. development of gpu's is 3-4 years so they arent going to base decisions on how the competition is performing 3 years from now, they are just going to reach the goals of the chip. i.e. performance, area, cost, etc.Quote:
