That said, the Gigabyte board can't translate the extra GHz to fps, as the H55N failed to improve much on its dismal showing in Crysis even with the i5-661 ticking over at 4.4GHz. Clearly there is something amiss with the PCI-E connection of this board. However, that's hardly a damning criticism, as by installing a card that's longer than the board and taller than the CPU cooler, you'd have to house the system in a micro-ATX case, and which point you should opt for a more adaptable micro-ATX motherboard. Overall then, it's a mostly impressive outing for the H55N, with the only downside a practical irrelevance.
