Originally Posted by
KaminoReal
I made a short list for you:
Memory problems:
- 24 GB ECC & W3520 fail to boot
- 12 GB only 8 GB detected
ACPI problems:
Shutdown/restart after S3 sleep dosen't work, I localized the bug in Super I/O sleep/wake methods(SIOS and SIOW) quick fix was to comment those calls on PTS/WAK.
FACP(FADT) table has some bugs like:
- PM Profile : 01 (Desktop) instead PM Profile : 03 (Workstation) it is a workstation board after all...
- P-State Control : E2 instead 00
- _CST Support : E3 instead 00
- CPU Cache Size : 0400 instead 0000
- Cache Flush Stride : 0010 instead 0000
- Reset Register Supported (V2) : 0 instead 1(this is important for legacy OS reset)
Devices:
- Intel Option ROM is outdated, please update it.
- Same for Marvell SAS, I saw some improved versions(especial on boot time) on other boards.
- Marvell eSATA is AHCI compliant? If yes I'd love to have the AHCI option instead legacy, it suits better for eSATA... I couldn't find any docs/datasheet for 88SE6121, Marvell is so "restrictive"...
Thanks!
P.S. I hope new BIOS version will keep good stuff for Xeon from 0001 or at least a beta will be leaked for us. :)
