Originally Posted by
ImmortalKenny
So here's an update:
After messing around with more and more settings in my BIOS, I still can't get my computer to go to the green loading Windows bar, it just stops after the "Windows was not properly shutdown" screen. I was also told on another forum that I could boot into Safe Mode, uninstall the CPU, then boot into Windows normally. Well when I try to do that, my computer hangs at the screen when Windows is loading the system files, specifically right after it loads crcdisk.sys (IIRC). Do you guys think my OS could be corrupt and is holding me back from unlocking the other two cores?
