@ Chicken Patty ... I'll use that song if I make a video :)
@ Aielman - the pins look similar to the Corsair, it may be slightly different size in the connectors ... dunno.
Promised pics yesterday, but got sidetracked installing everything so I could at least test out the hardware. Took forever to do my Windows updates, as I had an old Vista disk with out SP1.
A couple quick snaps:
I'm hoping it will look a bit better when I finish sleeving the cables :p:
http://shazza53.smugmug.com/photos/5...14_S3AVB-M.jpg
Not a great shot of the CPU water block ... its the NexXxus Bold Highflow X2:
http://shazza53.smugmug.com/photos/5...08_4za35-M.jpg
Temps look good ... actually a bit too good, so I've asked in the AMD section for some guidance to make sure I'm testing properly. At 3.2GHz, CPU is showing 32 at idle, and 39-40 at load. So far tested with OCCT and Prime95. Ambient is about 23. GPU is low 30s, but haven't run any vid stressing yet.
Loop is set up as follows:
MCP 355 > Magicool Extreme 240 Rad > CPU (BE 955) > GPU (4870x2) > Magicool Extreme 240 > XSPC Res Top
More to follow, my wires are beckoning.
