Dude... tell me how you looked up the links? You didn't use the search function and then post the URL as a result of the search? Just trying to eliminate a few things.
I went through the gallery page by page and copied the link to the individual posts, such as yours above:
http://www.xtremesystems.org/forums/...&postcount=151
The &postcount=151 can be omitted since it tracks the post number (p=4032153)
Still working on finding the answer. This is the first time we have seen this kind of damage.
My all internal WC system !
It's very simple. Hope you like it.
:up:
Crazy easy case to work with, but Here's my MM Pinnacle 24: http://www.xtremesystems.org/forums/...2&postcount=24
--Matt
Sweet, your fixing it. :up:
All internal Cosmos 1000 build log: http://www.xtremesystems.org/forums/...d.php?t=236919
missed one haf932 all internal http://www.xtremesystems.org/forums/...&postcount=363
case ASUS TA231
http://img411.imageshack.us/img411/6107/03tr4.th.jpghttp://img187.imageshack.us/img187/9942/07ea7.th.jpghttp://img509.imageshack.us/img509/8636/09pp6.th.jpg
err... work w/o cable management about 1,5Yr :)
Case - Coolermaster ATCS 840
http://www.thomasyu.im/revised-loop-side.jpg
You can find more pictures in my worklog which is in my signature.
Missing the Black Pearls in your list :)
http://www.xtremesystems.org/forums/...d.php?t=227100
http://www.xtremesystems.org/forums/...d.php?t=236785
http://www.xtremesystems.org/forums/...d.php?t=237304
http://www.xtremesystems.org/forums/...d.php?t=196446
http://www.xtremesystems.org/forums/...d.php?t=242328
otherwise - GREAT POST :up:
My AO5 Build log
http://www.xtremesystems.org/forums/...d.php?t=196117
My Antec 1200, soon to be updated with a new Apogee xt block and possibly a second 220 Rad.
http://www.xtremesystems.org/forums/...postcount=1681
my litle "Microsmos"
I think its done......
I just need to change the RES position when the i5 comes, the MoBo is wider.
The exit of the REs would touch the DIMM's.... and add a top exhaust fan.
thight, but worthy fit.
Dont bother about it being 5 pics, they're rather small...
http://img52.imageshack.us/img52/2481/sdc10212x.jpg http://img713.imageshack.us/img713/5127/sdc10211j.jpg http://img29.imageshack.us/img29/48/sdc10210e.jpg http://img708.imageshack.us/img708/1209/sdc10208.jpg http://img52.imageshack.us/img52/8374/sdc10205t.jpg
Lian Li PC-8n, I want to add a 1x120 rad, do some sleeving and potentially add another 5850 later on.
Also I would like to remove the side of the rad cover and replace it with a black metal panel instead of plexi.
http://i59.photobucket.com/albums/g2...r/IMG_0011.jpg
http://i59.photobucket.com/albums/g2...r/IMG_0001.jpg
http://i59.photobucket.com/albums/g2...IMG_0007-2.jpg
http://i59.photobucket.com/albums/g2...r/IMG_0010.jpg
here you go, here is my all internal midtower.. still a lot of work im planning on doing to it but here it is as it sits now
http://i70.photobucket.com/albums/i8...00210-2038.jpg
http://i70.photobucket.com/albums/i8...00210-2036.jpg
