Originally Posted by
SF3D
Too much mass in the base will still be a problem, even if you are using Deneb. If you start for example Wprime 1024 and watch the temps, you can see, that it will be stable first and then it is starting to get warmer and warmer.. If your base is not balanced right, you can't do nothing. You have a full pot of LN2 and the temperature is still raising up. Very light applications will not suffer from this and heavy pot might work well.
Monteboy- Let us know how it is working.
In general, everyone should remember to check how well the sensor + thermometer can read temperatures.. I have three different sensors and only one is reading correctly at -196C. Othe one show -160C and one -175C
