Originally Posted by
RayderR6
I got a dollar that says if you: (Warning: if you do this, you might have some cleaning up of a dual boot OS to go back to your original config, VistaBootPro is a great little tool to clean this stuff up, but if you don't want to deal with any of it, don't try anything below, thanks)
1) move the Titan to first boot in HDD list
2) install vista on the Titan (you'll have a dual boot OS now with your Raided OCZ's)
3) make sure in dual boot menu, you're selecting the Titan install (I figure it to be first and the default selection, i.e. let it go)
4) after vista is done with the final reboot, remove the vista dvd, reboot and see if you get a BootMgr missing.
If you do get a BootMgr missing, change your HDD disk first priority to your OCZ Raid volume and you will get into your dual boot OS menu again. If that works, change the Titan back to first HDD boot priority and put in vista dvd, reboot and see if you get you dual boot OS menu again.
If it goes this way for you, we have a very similar setup, with the exact same problem in using that setup.
