Yeah but com'on, hardly anyone here uses the stock cooling for more than a month ;)
For CF, just do the reverse mount on the upper card.
temps look just like the 3870's when i got them but after flashing bios they came down to about 65c
I don't think they used a proper GPU loading tool (fur wtf?). Their relative wattage results for well-known products (GX2 for example) are completely different than other sites, eg Anandtech.
http://www.anandtech.com/video/showdoc.aspx?i=3334&p=9
In the Anandtech review, there was a large difference between the X2 and the single GPU products, for example. There's almost no difference in the EXPreview test.
No it's not cuz of the cooling design. It uses almost the same wattage as the GTX280. ATi claims only 160w full load vs 236w with the GTX280 which is clearly a LIE.
pfft this is xtreme systems... volt mods and water cooling for everyone :P
full cover might not work with the 4870s but it looks like mounting holes are the same otherwise..
Why do you say that full cover might not work:confused:?
Only cause the RAM is arranged slightly differently but actually looking at it, the cover might still work anyways (since part of it is angled).
Look at that AA rock and roll!
Your predictions were pretty spot on... except you said R700 and not RV770! R700 is yet to come..
Now is the time for the smart ones among us to be buying AMD shares. AMD now owns the graphics market for this generation and as such is extremely under valued.
I read the Chinese version of the review, the card is looking good. If they are selling it for $299 it'll be the best performance/value balanced card out there right now.
Like this?
http://xoqolatl.ovh.org/files/cram1.jpg
I made the mistake of passing up AMD shares @ 3.50 before (they eventually rose to 40). From the look of things AMD is going to be in a stronger position this generation than NVIDIA was in the last one. That alone doubles, perhaps triples AMD's current valuation. I missed the gravy train once when I should have bought, I'd feel foolish to do so again.
wow good call. according to them gtx280 is only 13% faster than HD4870. (but almost 2x price)
Very nice success from AMD. :up:
Competition is good because it will push Nvidia even farther to extend the performance lead.
I would be cautious about buying AMD stock though they have huge problems competing against Intel in the CPU market that are not going away. ;)
Its just going to get worse for AMD after Nehalem imho.
What good does it do to be right on a total guess though? Unless you logically deduced these numbers, you could be right 20 times, it doesn't make you any more valuable or intelligent about the technology driving performance.
And I'm not sure what you're proving as you mentioned R700. The only thing I actually see you were right on was the GT200 performance over G92/G80.
i meant RV 770. was bad typing(I'm transitioning to dvorak from qwerty). note how there is no RV700.
and I logically deducted the numbers from rumored specs and the like.
next prediction 4870x2 faster than GTX 280 gx2 given that the rumors of it being driven at a hardware(as opposed to software) level are correct.
