http://www.momoshare.com/file.php?fi...426289f325f84a
here you go. Let us know how things go with this bios.
Don't worry...those Twintech's didn't work on my Gigabyte X48T-DQ6 as well...
It's a graphics card BIOS related issue.
I'll grab some VGAs tomorrow ( if I make it in time ) and start my tests with them.
For now... I'm stuck with a PCI "SuperPi" graphics card on the Striker II Extreme :p:
hi guys
i've a striker ii extreme here to test and also have serious problems. anything above 350mhz fsb isn't stable at all.
also my 74gb raptor got corrupted a few hours ago. :(
5200 PCI FTW! new 06 WR i'll bet :rocker: :D
When I say not looking good I was actually referring to all these incompatibilities we keep getting that seem to be cropping up with more and more regularity.
After building close to a thousand systems over the last 10 years I can honestly say that I have had more hardware throwing its toys out of the pram in the last 12 months than the last 7 years put together.
I am not liking this trend line :/
lol.
I'm going to NYC this weekend and I was going to pick up a 790I while I was over.... but because of all the problems the UK price has dropped so much it is barely more expensive here now... :rolleyes:
Flawless...loss :D
Data loss to be precise.
My first corrupted Windows installation.
Gay RAM timings ( 100% stable ) and low FSB ( 450MHz ).
Thank you 790i, thank you Asus!
I have not tried it. I got it from the EVGA forums. It is the bios that was sent out to one of the board review websites. Let me see if I can find more info for you.
edit: it came from here http://www.hardwarextreme.de
That's all I know. I would gladly delete this post if someone else has a more reputable source. Sorry, I just thought I would make it available.
Pulled my S2E out again to play around with my E8400, and have had a better time, although there are some serious FSB holes...
ASUS Striker II Extreme
CellShock DDR3-1800
nVidia 8600GT
WD RaptorX 150GB
ALL AIR COOLED
CPU - Arctic Cooling Freezer Pro 7
S2E - Stock cooling
ALL TEST: Unlinked, Memory speed locked at 1800 8-7-6-21 1.9V
ALL VOLTAGES: AUTO except CPU/RAM and stated otherwise
P1 P2: AUTO
FSB 333 - default - boot - stable
FSB 425 - no boot
FSB 450 - no boot
FSB 500 - boot - 100% stable - no corruption
FSB 525 - boot - 100% stable - no corruption
FSB 550 - boot - 100% stable - no corruption
FSB 575 - bumped VTT - Boot - not stable - no corruption
All of the above settings had crappy bandwidth, 8000 read 11500 write 74ns.
With P1P2 Enabled the board behaves very erratic.. if you manages to post, then the system seems stable, with memory performance on par with EVGA reference 790i.
Swapped out the E8400 and fitted a Q6600.
First Boot: FSB 450 x8 - boot - restarted after 20min of ORTHOS
after that all went into crap... with the same settings, it may boot, it may not. P1/P2 or not, the S2E has got an attitude problem with quads... :shrug:\
HOWEVER; seems that having memory at 1800 is NOT causing corruption of the OS("is preventing OS corruption" would be too conclusive). Silver lining?:rolleyes:
Do you know how pissed I am right now? wow I cant believe I missed that one!!!
Well at least ZZF seems to be lowering the price of the board. Thanks for the heads up but wow all because I needed to sleep one day and this big promo happens the day I deciede to take a break...
All these problems make me think it's an SPP problem. Since it's NV's first
DDR3 memory controller, I think they have a lot of divider issues.It reminds me of my early P5WDH memory divider issues.Hope it's gets better as the bios matures. It got better on the P5WDH as the BIOS matured, so hoping the same(Crosses fingers).
I've been lucky so far, no corruption yet.
when trying to push the memory to extreme I got tons of OS corruptions - even when running dual Spi 32m, and I crash - after reboot XP will be corrupt50% of the times. Thanks god it only takes me 1min to restore OS thanks to xxcopy
My board just died after 1 hour!!! :eek: i set up an advanced rma, hope i get a new one soon.......it just died, just like that, refuses to boot, i get a blue power light on the board, but the board is dead......crap quality for a $350 board.
This is BS ...
My results with E8400Code:Originally Posted by eternal_fantasy
FSB 425 - no boot
FSB 450 - no boot
FSB 333 - boot - stable
FSB 400 - boot - stable
FSB 450 - boot - stable ... everything on default except RAM
FSB 500 - boot - stable
FSB 525 - boot - unstable
With Q9300
The same, but max stable is 470MHz FSB ...
With Q6700
No go higher then 370MHz FSB ...
Argh !!!! I am having no luck with this board at all. Got my replacement S2E, put everything back together with my E3110, reinstalled windows xp just to be safe. Ran everything @ default, SPI 32M frezees the system. I mean the system is hard locked with everything on auto. This is crazy. $450 worth POS. ARGH:mad: :shakes: :brick: and I am running out of smilies.
