Congratulations on breaking 9 minutes! :clap: :clap: :clap:
Amazing... :eek:
Amazing... :eek:
:eek2:
NewBeetle you have just dominated the whole SPi world! This sub-9m run will be remembered for a long time! Congratulations!
I think that with new board you can also improve other records! (like 16M for example :D), am I right? :D
Many thanks all and always!!! :toast: :toast: :toast:
I will not forget your congratulations through my life. :D
@x9 ratio, my P5K is a little stabler than my P5K-E.
But @x10, my P5K-E is a little stabler than my P5K. :p:
Good luck, Zannema-san! :up:
How to improve "performance level" is the setting of "CPU PLL Voltage" in my system (CPU#7 & P5K-E).
Only setting it to "AUTO", the level "7" can work. :eek:
It was a blind point for me.
And I think my vanilla can work Lebel "7" if it is the same setting as P5K-E.
DEWA DEWA ~
NewBeetle
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
:shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked: :shocked::rocker: :rocker: :rocker: :rocker: :rocker: :rocker: :rocker: :rocker: :toast: :toast: :toast: :toast: :toast: :toast: :toast: :toast:
Awesome!:up:
another spi milestone broken ...
amazing clock and result NewBeetle :clap: :clap: :clap:
Holy superpi LN2 ownage NEWBEETLE!!!!!!! :clap: :clap:
whoah jst got wrong mb p35,but then again can,t give it constant supply of ln2 either.Very impressive gj thx
Wow!:eek:
Under 9 Minutes in 32M it's incredible!:clap:
Thank you all !!! :toast: :toast: :toast:
Thank you for your wonderful congratulations! :D
Thank you so much for your congratulations, k|ngp|n-san.
You celebrate and I am very happy now. :D
It is an awful word for me,Gautam-san. :p:
Again, thank you so much, massman-san, erwinz-san, Hyperr-san, ent-san, qballe-san, chester-san, nachthymnen-san !!! :toast: :toast: :toast:
DEWA DEWA ~
NewBeetle
Congrats :).
How about 630 x 9 for pi32m?
Very impressive Mitsuaki-san!!!
Great achievement! :D :toast:
That CPU is a real killer. When will you start benching 3D? :)
Very nice runs Newbeetle-san ;) I'd love to play with such a great CPU...
Congrats :toast:
It only took you 6 weeks, now didn't IT :)
After 1M, that was another wall that simply gave in to you, tired of all that restless smashing, NewBeetle :up:
Huge congrats :toast:
I was sure, you will be first person, who can run under 9 min. :up:
Great cpu, and greater master! Congratulations!:toast:
Now, you must go :party: :cool:
Team Japan is the true SPI king! :up: :yepp:
Many thanks all!!! :toast:
At present, it is difficult. :(
However, I do not think it is impossible. ;)
I did 3D bench only once with 7900GTO-SLI.
However, I did not continue because it cost too much. :(
I want to try again if there is a good sponsor. :p:
Thank you so much for your congratulations always, before-san :)
I know you are one of the greatest pi bencher in the world.;)
I wish the goddess of OC to bring you a great CPU like your FX-57(San Diego) again. :up:
Thank you so much for your encouragement. ;)
However, I want to take the rest only a little now. :p:
Thank you always, over-san.
This result is a favor of this great cpu. :D
I make an effort to demonstrate the ability of this chip. ;)
Again at the end, thank you so much, M3kk-san, Fr3ak-san, before-san, bachus_anonym-san, over@locker886-san, and rick_fx-san :toast:
DEWA DEWA ~
NewBeetle
I'm sure you'll be the first to break the 8 sec barrier with the 45nm Wolfdales :D 6GHz for the 45nm anyone? :D
Thank you for your comment. :D
I wish I can do it by ..middle range.. CPU. :p:
Here is the image of my 4CPU-Pots + 1Chipset-Pot.
http://homepage2.nifty.com/NewBeetle/Pot_4+1.jpg
From the left side : Maxx NEO, Kuri-Pro 2, Kuri-Pro 4, V-TEC ARC Pot Rev.12.0XE
Center : Tara-chan 1st
1. Maxx NEO (90mm x 60mm x 120mm / 2050g) by TAM
For P4(Prescott,Cedar Mill)
Extra high-power CPU Pot, but it is difficult to treat and it awfully cools surrounding capacitors. :p:
2. Kuri-Pro 2 (60mm x 120mm / 1340g) by TAM
For Athlon XP(Barton), Athlon 64(Winchester,ClawHammer),Core2DUO(Merom), Pentium M(Dothan)
It's a basic model and the temperature management is easy. ;)
3.Kuri-Pro 4 (70mm x 150mm / 1650g) by TAM
For P4(Prescott,Cedar Mill), Core2DUO(Conroe)
It is easy to treat, gets cold well, and LN2 cost is good,too. :cool:
4.V-TEC ARC Pot Rev.12.0XE by Vigor
Only for Pentium M780 (I got pifast WR with this pot : 07-28-2005)
Special one of model made for me by Vigor. :up:
5.Tara-chan 1st (40mm x 60mm) by Kimuchi
For Chipset
It is the lethal weapon of chipset cooling. :D
DEWA DEWA ~
NewBeetle
:shocked: lots off copper over there .
btw newbeetle what dose dewa meen ? :D
the Tara-chan 1st.. looks really cute ;) thanks for posting the pic of your containers they are awesome :up:..
and like blind_ripper i would like yo know too what does dewa dewa mean..
Impressive container round-up ...
Newbeetle, how much helps the watercooled Northbridge and southbridge to get te overclock stable? Is it just a matter of 1-2mhz higher than with aircooling or am I wrong here?
The advantage of watercooled might be about 2-5MHz. :p:
However, watercooled might be considerably advantageous if becoming long distance like 32M.
For me the maximum advantage of watercooled is not to cause the flow of air.
The flow of air should be a little because it makes frost and dew on the board. :(
Therefore, FAN is used to cool the memory by a minimum amount of the wind. :cool:
DEWA DEWA ~
NewBeetle
Thank you for the images and explanations of the POTS, your comments about airflow are very informative too. Again your generous spirit with information and help is greatly appreciated. May you go from strength to strength.
