Yes, i explained it on some other posts, as here, here and also here
Btw, finally my NB Voltage is upped two notches (1.18V BIOS - 1.205V Measured) and one at FSB (1.32V BIOS - 1.24V Measured) to make F@H stable with SMP and GPU at the same time, also i had to set the CPU GTL Ref to 0.61x to avoid sudden reboots
I can explain further if you need it :) Thank you :up:
