you're probably going to have to run a lower divider, and underclock your ramQuote:
I hope so. I just need to get some tubing and find the time to assemble it all.Quote:
Originally Posted by Repoman
If I run C&Q with my voltage only at 1.375v, you don't think it will be harmful at all do you?
I mean, it's only 0.025v above stock...
I'd rather save energy, and keep my pc cool as much as possible.
Thanks.
Holy mackerel! - that’s some sweet numbers you got going thunder!Quote:
Originally Posted by thunderstruck!
I wonder how it would fair against a Conroe @ 3.2Ghz not that I think it would beat it but I would like to get a picture of the performance scaling between the two processors because I read AMD will push the FX line up to 3.6Ghz on the upcoming 4x4 line.
hmmm... 4 cores @ 3.6Ghz :slobber:
can you post a screenshot of a64? we have very similar hardware but your results are so much better then mine. i have to burn in just for 2.8 @ 1.45v :slap:Quote:
Originally Posted by Burky
even with 1/2 divider :upset:
3.6ghz dual core isn't coming anytime soonQuote:
Originally Posted by Smalltimer
not fair I do 3 ghz @ about 1.525/1.55 volts which I thought was pretty good for air...Quote:
2.8ghz on 1.275 volts is unreal...
I always idle 38 degrees with a big typhoon pushing about, I'd say 50-75 cfm...seems kind of high, load is about 45
not fair? i need 1.475 for 2.8 :upset:
i dare anyone to find a CCBBE as bad as mine
Mine? Hehe, we shall see? I'm kinda hoping it's not though :D. More testing to come later, very busy now with damn homework.
I have not tried a whole lot with my CCBBE on stock volts but I dont think it'll do 2.65 at stock volts. For some reason it has scaled well and is almost stable at 3.0ghz. Better than my last ccbbe which topped out around 2.9
Originally Posted by blazin-asian
my second one needed 1.55 or something like that for 2.8. .........but i sold it and he only needed 1.425 for 2.8 wierd........my set up must suck or something. owell 2.9 @ 1.5v now so im happy with my set up.:slap: o if this helps any my curreny chip is the 904 what ever.
Got an Opteron 165 CCBBE 0615 DPMW from tankguys running in an Epox
9NPA+ SLI. It's dual priming @ 2880 (320x9) 1.45vcore now on the stock heatsink with a Tornado at 7v. Seems stable so far. It went up to 2835 (315x9) on stock vcore + .025 (Epox BIOS setting).
I'm hoping I can get 2900 out of her with the stock heatsink.
Keep in mind that was with the AMD heatsink and fanQuote:
It's nothing compared to this:
http://img53.imageshack.us/img53/734/63kz9zc.th.gif
:D
Nice clock for such a low vcore. :toast:Quote:
Either I don't know how to use A64 (I never needed it), or it's showing the wrong numbers.Quote:
Here are my ram settings:
DRAM Frequency Set - 180=RAM/FSB:05/6
Command Per Clock (CPC) - Enable
CAS Latency Control (Tcl) - 3
RAS# to CAS# delay (Trcd) - 04 Bus Clocks
Min RAS# active time (Tras) - 06 Bus Clocks
Row precharge time (Trp) - 03 Bus Clocks
Row Cycle time (Trc) - 07 Bus Clocks
Row refresh cyc time (Trfc) - 14 Bus Clocks
Row to Row delay (Trrd) - 03 Bus Clocks
Write recovery time (Twr) - 02 Bus Clocks
Write to Read delay (Twtr) - 02 Bus Clocks
Read to Write delay (Trwt) - 03 Bus Clocks
Refresh Period (Tref) - 3120 Cycles
Write CAS Latency (Twcl) - Auto
DRAM Bank Interleave - Enabled
The next setting was with increased skew.
The rest I haven't touched.
What BIOS are you using?
I'm using 704-2 Beta, try that if you haven't already.
I wussed out and turned the Tornado up to full blast. I am happy to say that it looks stable (enough for me, I'm impatient). I will probably settle with this clock, for awhile. The vcore is usually 1.45, that's a little Epox fluctuation in the pic. I'm definitely happy with this cpu. One core usually fails by now if it's going to, from what I've seen so far.
:clap: :woot: http://home.comcast.net/~kilyin/bong.gif
http://home.comcast.net/~kilyin/oc3.jpghttp://home.comcast.net/~kilyin/oc4.jpg
any idea what can i tweak in my bios to stabilise my 305x10 overclocks ?
other than vcore that is.
and also whats the max vcore i can go while not killing the chip?
Make sure you are running your ram below stock speeds so that you can remove that from the equation for instability.
Try changing the LDT and/or chipset voltage. Usually it has little or no effect, but it's worth trying.
What are your specs?
Heh, that's what I thought. Yesterday I failed after three and a half hours. I was surfing the internet as well though, with pdfs, so I think that I induced my error. I will prime another time and get it for longer.Quote:
Originally Posted by Kilyin
Also, was that a dual prime there?
I can't quite make it out.
Mod your TTBT with a panaflo fan and i'm sure u'll get anything stable. There's some panaflo's that run at 114cfm :D:D:D
That's amazing. The stock fan must do about a quarter of that...
Only problem is for me is that I'm in France, and I have never seen any Panaflo fans anywhere (though I have searched quite thoroughly).
There is this one though:
I can get this new: http://www.achetezfacile.com/coolerm...rix-89436.html
Or two of these off ebay: http://cgi.ebay.co.uk/2-X-PANAFLO-12...QQcmdZViewItem
Which one do you think?
Should I get two of the 112cmf fans, one for the exhaust as well?
Well I received my first CCBE1 0606 VPMW (OEM) from flickerdown today.
I was going to wait until this evening to unpack and mount everything meticulously but then I got impatient and was unable to contain myself.
The temps are higher on the 0606 than my older 0546 by aprox. +4c
I checked the two in sucession and cofirmed this one runs hotter.
I adjusted my vcore to 1.3v and overlocked to 2.6. I ran some rather large rendering tiles 2GB Ram and left it work for a few mins. The overall temps rose and maintained 53-4c
I moved my ram up to 301Mhz and booted up at 2.71Ghz and began the same render, this time I received an error within 4 minutes. It could be memory of chipset settings though...
Does anyone know what adjustements should be made on an A8N32-SLI above 290Mhz FSB?
My Opty 175 CCBWE 0543, yea...gets to 218x11 on stock volts...don't have much time to push it yet...going to wait until I either sell it, or put it under my H2O setup in my new and upcoming rig in the next month.
Yeah, dual primes large FFT. I had them side by side, but the pic was ginormous, so I chopped it up.Quote:
What are the primary caused of the following 165 behavior:
CPU stable with 1.24v up to 2.6Ghz
CPU unstable with any voltage above 2.61Ghz (prime fails early)
I tried various voltages and the results are always the same. Anything above 2.61Ghz will cause cpu to fail.
I wondered if anyone had been through anything like this also?
i have that issue sometimes. clearing the CMOS cures it for me.Quote:
