Nope, if it would, the board would be trash, it wouldn't boot at all! U use 5.0ns when you exceed ~270 fsbQuote:
@NFM: the Rev3 has 5.0ns ??
oh okay , thanks for this tip ... I'm french so I don't understand at the first read ;-)
So, there I try too. I had near exactly 1,8V and i don't believe that the motherboard give such tension... :|Quote:
Originally Posted by kasius
in bios: 1,4 + 5%
on meter electric: 1,8V
Some other ideas?
@ need.for.mhz
DQS skew will be very different for everyone, it's basiaclly the skew delay.
Which is the small time difference when signals are received compared to one another.
It will most of the time be within a certain range especailly on the same board, but depending on the rams can be very different, maybe we can test will only 808 brainpower pcbs and see if the same settings helps everyone with the same ram pcbs and chips too maybe.
Read preamble of 5ns works better for me as well.
Can someone sen me this bios: v1.8Mod [NFM] Rev.3 BIOS
nfm's server seems to be overloaded :(
mail: gregat [a] gmail.com
Tnx
is it possible to get less than 1.1 Volt for the CPU on that board?
The Bios option is ignored. When I set it to 0.8 Volt and 800 Mhz defaultspeed, I get in Windows always 1.1 Volt.
Other Tweakers like RMClock or Clockgen show also that problem. No less than 1.1 Volt. :(
I got a Venice 3000+ and 1.8 normal bios. Is it because the Bios doesnt know the CPU?
Server is my server and i doupt it can get overloaded. Maybe just a isp issue try again.Quote:
Originally Posted by Moonman
Why would you want under 1.1 volts anyway the chip would run super cool at that voltage.Quote:
Originally Posted by mapel110
I'd just like to thank NFM for his modded boises! Using 1.80 rev2, i just broke 30s for the 1st time in the unpatched Super-Pi 1M (29.988s)...at 10x280 and 1:1 memory @ 2.5-3-3-7. :D
Next i'll try the SSE3 patched version and break 29s. ;)
I need a bios to run 300HTT, 3x HT, 8x CPU, 133 divider, 2.5-3-3-10. I can't boot at that currently. I a, using 260 HTT, 9x CPU, 133 divider now. That would be fine if there was a 150 divider.
Blinkme323 if your system doesn't even post at these settings a bios mod can't help you. The code is executed at end of the bios part, so does your system hang after the bios finished, or does is not post at all?
Edit: 1.96 BETA is out. http://msi-forum.de/thread.php?threadid=17502
Hi, I've got Winch + 2x512 corsair xl v1.1 maxes out at 240htt, using 2.5-3-3-8
cpu@280x10 -166 max /mem at 234 -- Pi 32mb stable, hoping might get few more mhz with a newer bios- on 1.36b @ moment.
I see a few new bios, which one's should I try?
OR which one's should I NOT try :)
I read the whole thread(quite a few times) but most of the memory settings info is well above my head sorry.
Any advice truly appreciated :)
Edit: this memory dosn't like twr = 2 clks - trwt = 2 clks when set in A64Tweaker, guess I'll stay where I am until I get better memory.
When I first got my mobo, I was running 1.8. I maxed out at 2.43cpu, 215 memory, and HTT was 315 but I didn't try to go higher. Now with the modded bios, which works great at my current setting, can only do 285 HTT. I need the best bios for a high HTT. Ram timings don't have to be real loose.
Nice one mate :banana:Quote:
Originally Posted by CD 1986
I tried NFM rev3. I could boot at 290-300 but blue screened while loading 2000. I am back to 265x9 instead of 295x8. They would do the same thing except I wouldn't b e underclocking my memory. BTW, I am only using 1.45v somehow. I doubt it is stable but I am typing from it.
1.96 beta gives me same error as 1.95 beta
Warning : Have Option Rom Can not be invoke (vendor ID: IODEH Device ID: OODFH)
The bios boots windows loads ok just cant enter bios setup. I tried removing all the fan headers but it didnt help. :slapass:
any ideas?
What flashing method did you use?
If you used winflash, make sure you ticked all the boxes so that the DMI area is updated as well as the main block of the bios, since 1.9b has a different bios structure from the older bioses.
Just flashed 1.9b6...
- the CPU multiplier option is now selectable and works
- the voltage options are back in % over-volt (upto 10%)
- the 216, 233, 250mhz memory dividers don't work correctly
- 183mhz divider not selectable in bios, but visible in modbin6
Maybe someone could try and activate the extra mem divider options, and the extra over-volt options? NFM? :)
I can't find anything on this mobo and the A64 X2 cpus. Did I just miss it or did MSI leave us hanging?
I believe that the new 1.9 bios will support X2. I just loaded on 1.9b6 and on the bootup screen (right hand side) it says "1 CPU" detected, therefore its probable that it can detect more cores also. ;)Quote:
Originally Posted by flenser
pls where to download this 1.9b6 biosQuote:
Thanks!
I hope they wait to release it until they get it right.
1.96 download link:
I'm really busy right now :( Will get back later today. btw nice to see 1.9B6 BIOS out.Waiting for offcial release :toast:Quote:
just everybody hang on
Waiting too. We will see that MSI guys knows to make!Quote:
Originally Posted by need.for.mhz
