not bad for 2.5-3-3-8 ;) ...
http://mitglied.lycos.de/siedl/8x290..._3_8_prime.jpg
DDR600 2.5-3-3-8 @2.8VDimm OCZ EL Rev.2 / 9x300 3400+ NC
memtest no problem boot windows cant boot!
i try to remove the IHS ... perhepas it help
http://mitglied.lycos.de/siedl/9x300...memtestnr5.jpg
probably @2700mhz isn't stable for cpu.. what cooling ?
try 8x 300HTT = 2400mhz
By removing the IHS can you kill your CPU?
yeah if you crush the core under it :)Quote:
Originally Posted by ugp
ok my cpu is at limit ;) ...
but multi 8 the ht go higher ;)
http://mitglied.lycos.de/siedl/8x300...memtestnr5.jpg
http://mitglied.lycos.de/siedl/8x300...perpi36sek.jpg
Just go nice & slow, & be careful. If you look closely, one side of the IHS doesn't have that glue stuff all the way across. :) While your at it, might as well see if the core needs lapped. :DQuote:
i got a lot more out of my cheapo ram!
just got 12mhz to HTT
now i can memtest 5 passes test 5 and prime for a while (i upped voltage when it crashed so its pretty stable, will run prime soon and memtest all night)
now 282x8 for a nice 2256mhz. beat ugp by 6 mhz!
oh cool i just realised that Mrki only has 512mb... makes me less jealous
pics are 70% quality but look better than reduced size
this is my score :)
Vapochill Light Speed
A64 3200+ Newcastle
DFI Lanparty UT nF3 250GB
2x256MB A-DATA PC4600 1:1
Antec True Control 550W
http://www.hwupgrade.it/articoli/111...a_max_vapo.jpg
http://utenti.lycos.it/swarzy85/SUPERPI32M.JPG
The max HTT's frequency i reached is 355Mhz (it finished Superpi 1M @ 6x355).
Next week i'll receive another CPU (3200+ Clawhammer) adn i hope to pass 400Mhz
the power that is DFI Bios or A64Tweaker, just check these benchmarks i did and how just changing the additional memory timings affected fps in CS:Source Stresstest!
Counterstrike: Source Stresstest
cpu @ stock speed
video card @ stock speed
only adjusting additional memory timings in DFI bios :)
AMD64 3700+ @ 12x201HTT = 2411mhz (stock)
DFI Lanparty UT NF3 250Gb 05/10/04 bios
Win2k SP4
128MB Gecube 9800Pro Extreme stock speed = 398/351
ATI drivers = Omega 8.07
2x 256MB KHX3200K2/512 BH-5 @ 201mhz 2-2-2-6 1T 10-13-2222 8x/4x/7ns 3120
Antialising mode - None
Filtering Mode - Trilinear
Model - High
Texture - High
Water Detail - reflect world
Shadow detail - high
Wait for Vert Sync - disabled
1024x768 = 125.05 fps
1280x1024 = 73.59 fps
1600x1200 = 56.67 fps
Antialising mode - 6xAA
Filtering Mode - 16xAF
Model - High
Texture - High
1024x768 = 82.84 fps
1280x1024 = 49.15 fps
1600x1200 = 17.32 fps
Tighten memory timings on ram a bit more.
2x 256MB KHX3200K2/512 BH-5 @ 201mhz 2-2-2-6 1T 8-12-2211 16x/7x/7ns 3120
Model - High
Texture - High
1024x768 = 83.49 fps
1280x1024 = 49.87 fps
1600x1200 = 23.40 fps
Now overclock video card @450/390 with tighten memory timings on ram
128MB Gecube 9800Pro Extreme stock speed = 450/390
2x 256MB KHX3200K2/512 BH-5 @ 201mhz 2-2-2-6 1T 8-12-2211 8x/4x/7ns 3120
Model - High
Texture - High
1024x768 = 130.46 fps
1280x1024 = 82.34 fps
1600x1200 = 63.69 fps
Model - High
Texture - High
1024x768 = 93.65 fps
1280x1024 = 53.76 fps
1600x1200 = 23.97 fps
Now overclock video card @475/400 with tighten memory timings on ram
128MB Gecube 9800Pro Extreme stock speed = 475/400
Model - High
Texture - High
1024x768 = 136.86 fps
1280x1024 = 85.98 fps
1600x1200 = 66.91 fps
Model - High
Texture - High
1024x768 = 98.79 fps
1280x1024 = 57.02 fps
1600x1200 = 20.29 fps <-- weird not sure why it's lower but i did do all these benchies in same win2k session
Nice testing man, I might have to do some testing on this as well...When I finish I will post my results as well.
In the attachment you see the max HTT freq. for my 3000+ NewCastle. Sadly i can't really get super high 1:1 speeds cause my BH5 is maxed out at 267 MHz @ 3,48v. And the second sad thing is that my CPU is not that great :p:
I also played some with the timings of my BH5, CAS 1,5 and other very low timings are no problem :banana:
Erik, how 'bout some voltage on the CPU? :DQuote:
Originally Posted by erik9287nl
Help!!! While I was testing high mem speeds on my BH-6, I lost the ability to use 2 sticks of RAM. :( I've tried using different DIMMs, different RAM, etc., etc., but it won't work anymore with 2 sticks. I've just replaced the HDD, and so obviously it's a fresh format & OS. But the RAM prob was before HDD replacement, and a fresh OS didn't straighten it out. :confused:
Yes you need more volt on cpu.
Dont be afraid cuz im not =)
Why in the hell are you running v2.0 to your CPU? LoL and aren't you using air cooling man??? You are crazy!Quote:
Originally Posted by Ubermann
lol....72C
burn baby burn :D
Yeah he took his IHS off and is wanting to kill the CPU i guess...
Hehe, the CPU doesn't like more voltage. Above plm. 1,85v Vcore the instability increases rapidly at any speed. This was just for testing the max HTT freq. on my NewCastle.Quote:
Originally Posted by Zeus
Lol, now i see i had the Vcore to 1,95v :p: Anyway, a pifast @ 2560 MHz can be done at 1,85v, but when i go higher i get errors. Just a crappy cpu. Good enough for me at the moment though :D
Well I gained almost 200MHz when reaching the max 12h prime stable clocks by removing HS and changing zalman 7000 Al/Cu to watercooling including Asetek Antarctica block and indirect compressor (temps are almost whatever I want them to be :D )....
When using aircooling my CPU would be unstable after 1.7V and that was because of temps not because it is a crappy one...
So this is were I am now... load temps were approx 25c when running Prime for 12 hours at 2684MHz...
You need to clean up that wiring boy! LoL! That is horrible looking though...I like my box to look good as well as run good :DQuote:
Originally Posted by jayl
As Bigtoe and others have recently reported, I found out how ram oc's depends on each individual AMD64's ondie memory controller.
i.e.
with my 2x AMD64 3400+ Newcastles i can't get my best single OCZ PC3700EB to do 3-2-2-8 only 3-3-2-8, but on my AMD64 3700+ this is what it does
283mhz 3-2-2-8 1T at 3.28v vdimm
http://www.fileshosts.com/AMD/DFI/60...m-buffFULL.jpg
http://www.fileshosts.com/AMD/DFI/60...11-14-2322.jpg
I suspect this as well and will be confirming it when I receive my new processor. Kind of makes you wish that the memory controller was on the board's chipset, huh?Quote:
Originally Posted by eva2000
Nah. Would be nice of AMD to refine their process(ors) more though ;)
I can get 248 out of 2x512 CH-5 @ 1.5-2-2-10-12-16 with 3.30v on my Clawhammer so far.. I guess I got a good one? EDIT - 1T.
So how are people liking these boards? I'm thinking about getting one.
