Hi everyone, this is my first post and i hope that some one can help my on my problem.
I've got some trouble with my bios configs (F6), every time when I'm playing BF Bad company 2 i've got random BSOD, but on running Prime95 it stay stable.
My rig config is:
I7 930 @ 4200 watercooled
Gigabyte UD7
Ripjaws PC3-1280 C8
HD 5870 watercooled
And bios config at the moment is:
I already try many different voltages configs but unfortunately the problem stays, BSOD :(Code:Advanced CPU Features:
CPU Clock Ratio ................................ [21]
Intel(R) Turbo Boost Tech ...................... [disable]
CPU Cores Enabled .............................. [All]
CPU Multi Threading .............................[disable]
CPU Enhanced Halt (C1E) ........................ [disable]
C3/C6/C7 State Support ......................... [disable]
CPU Thermal Monitor ............................ [enable]
CPU EIST Function .............................. [disable]
Virtualization Technology ...................... [disable]
Bi-Directional PROCHOT ......................... [enable]
Uncore & QPI Features:
QPI Link Speed ..............................[7.20]
Uncore Frequency ............................[3.400]
Isonchronous Frequency ......................[enable]
Standard Clock Control:
Base Clock (BCLK) Control .......................... [enable]
BCLK Frequency (MHz) ................................[200]
PCI Express Frequency (MHz) ........................ [100]
C.I.A.2........................................... .. [disable]
Advanced Clock Control:
CPU Clock Drive ..............................[700]
PCI Express Clock Drive ................... [700]
CPU Clock Skew ............................. [0]
IOH Clock Skew ............................. [0]
Advanced DRAM Features:
Performance Enhance ...................... [Turbo]
Extreme Memory Profile (X.M.P) ........... [disable]
System Memory Multiplier (SPD) ........... [8.0]
DRAM Timing Selectable (SPD) ............. [quick]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................[8]
tRCD ..................................[8]
tRP ...................................[8]
tRAS ..................................[24]
CR.....................................[1]
B2B.....................................[]
Advanced Voltage Control:
CPU Intel Core i7 920 D0 Stepping
Load Line Calibration ................. [Level 2]
CPU Vcore ..............................[1.28125]
QPI/VTT Voltage 1.150v .................[1.315]
CPU PLL 1.800v .........................[1.84]
PCIE 1.500v ...........................[1.500]
QPI PLL 1.100v ........................[1.200]
IOH Core 1.100v .......................[1.800]
ICH I/O 1.500v ........................[1.600]
ICH Core 1.1v .........................[1.400]
DRAM
DRAM Voltage 1.500v .............. [1.64]
DRAM Termination 0.750v.......... [AUTO]
Ch-A Data VRef. 0.750v ...........[AUTO]
Ch-B Data VRef. 0.750v ...........[AUTO]
Ch-C Data VRef. 0.750v ...........[AUTO]
Ch-A Address VRef. 0.750v ........[AUTO]
Ch-B Address VRef. 0.750v ........[AUTO]
Ch-C Address VRef. 0.750v ........[AUTO]
If some one have any idea what cant by the problem i will appreciate.
