Anandtech addresses those concerns here
http://www.anandtech.com/cpuchipsets...oc.aspx?i=3502
hi
now on f5g bios no change from f5a
still at 21 x 200
have a major problem, 17 965 ex , X58-UD5 F4 Bios ,3* Corsair Dominator 3GB kit , Corsair HX1000W psu.
My problem ate that i cant have all 3 mem in get no boot and error cod 85, tested all mem in each slot so they are all working in single.
I can have all mem in but 2 in blue slots an one in white slots.
Any suggestion how to solve this..
which QPI LINK SPEED I should choose for a 3.8 overclock on a 920
36 is correct, also when you select your memory multi make sure you select your uncore multi to be one click above twice the memory. example - if you set memory to x6, make sure you set uncore to x13
Ok thanks had no luck with bios f4 no matter what I did. flashed to F5G and at least already at 3.880 with turbo on. the isochronous support should be enable or disable?
also could you help with the voltage on the below settings
QPI/VTT
IOH voltage
qpi pll voltage
ICH I/O
ICH CORE
hlonipha
Is it possible for a RAM to run at CL4 at 800MHz ? Yesterday, my Dominator Ram was running at CL4 (4-8-8-24 @ 800 Mhz) - as per CPU-Z and Everest both. I got worried as I didn't have memory cooler so I rebooted to check in BIOS if I accidentally set it to 4, but it was shown as 8. When I came back in Windows its was back to 8.
Can it be just a bug or was my RAM actually running at CL4.
I can not boot without turbo mode on. ummm priming at 3948mhz with turbo mode on at 1.31v
the lowest vcore that I could get 4ghz (ht on) prime stable was 1.4v - set in bios - see below - (note - all this was on air - noctua 12 with 2x ultra kaze in push pull)
it failed AT 1.31 BIOS setting but im using HT OFF.
What were your other settings for your 21x196 settings. I did not get the TRUE today in the mail so still working with the stock cooler.what was your
QPI/VTT Voltage
IOH
CPU PLL
QPI PLL
well done for the night settle for 3800. on this stock cooling the temps were going really high while anything above it. hopefully tomorrow I et the new true. and can start testing again
I've settled for 3.8 as well due to stock cooling. I'm waiting for my Crossbow retention kit to get here, so I can use it with my Vendetta 2.
Hello Guys,
So many bios updates and I'm confuse which one to used, for EX58 Extreme what is the most stable and have fewer bugs bios update you used?
Most of people using F4j or F4m
I am using F5E... with no problems and suposedly fix the sleep mode thing
using everest and prime95 my motherboard temps idle at 31C and loads to about 42C
anybody for comparison?
