Originally Posted by
xguntherc
yes you should start another topic about this. also the 1200 is a big case, you could easily get a nice radiator and put it vertical in the drive bay's. I've seen many people do that on there 1200's and even in the 900. it will work. there is plenty of room.
Personally, I'd spend the $51 dollars and get the TRUE.. add a nice fan to it. Overclock your Q9650 to where you want it.. and then slowly learn more about water-cooling, and wait for that 200mm RAD to be released, and actually used, and or reviewed to see if it's any good. if so, get it.. but I'd rather not.. or wait and get a water loop, either way. I'd get the true because it's just a great cooler. you can use it while you learn, and build your water loop. (That is what I did) and I'm saving it, because there will come a time where you want to go back to air, or you'll need to upgrade, want a new CPU block, your pump dies, something. and you'll need a air cooler and wish you had something like the true so you could still use you high, nice clocks..
Personally, I give Antec a B+ for trying. lol. but until that is released. I'd not bet on it at ALL.. not only do we know nothing about the type of rad, how well it handles heat, how big it is in comparison to ur regular dual, and triple rad's. but ANY rad on the market. ANY, other then maybe the PA series, and the Feser Rad's. ANY other RAD needs fast, high RPM, CFM heavy fans to blow through the rad. I'm sorry but the 200mm fan on the antec may be a nice fan, but it runs very slow.. what 900rpm. it moves 100CFM+ of air only because of it's size, there is no way it pushes hard enough to be a good fan to use on a radiator.
I could be wrong, but I just don't see that fan being strong enough for a radiator, unless they pulled some magic on that 200mm rad.
Either way, good luck. you might want to start a water thread! (in Liquid Cooling section of course)
