Ok I found this template from ATLNY, his specs are similiar to mine, except he has 4gb of pc6400 and I have 4gb of pc 8500, I set everything according to his and I could not boot. I know before I started changing the settings I had my DRAM Freq set at 1066 and when I made some changes it went to 1357, I can only assume this is my problem, I should have had the DRAM Freq set to auto before I started? Also I may need to adjust the DRAM Voltage different than his? I am really only looking to go 3.6ghz if that helps at all?
His specs
Spec:
E8400 @ 4005 MHz @ 1.34v
Maximus II , P45 chipset
GeForce 9600GT
Corsair XMS2 DHX DDR2PC6400 (4 GB)
(2) Seagate 320 RAID 0
PS. Corsair VX550W
LIAN LI PC-60BPLUSII
Windows Vista Ultimate x64
Cooling: Swiftech H20-220 Apex Ultra
His template
My specsCode:Asus Maximus Formula II Bios 0901
Corsair VX550W 550W
Cpu E84000
Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
Ratio CMOS Setting: 9
FSB Frequency: 424
CPU Clock Skew: auto
NB Clock Skew: auto
FSB Strap to North Bridge: 333
DRAM Freq: Auto
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : auto
Row Refresh Cycle Time : auto
Write Recovery Time : auto
Read to Precharge Time : auto
Read to Write Delay (S/D) :auto
Write to Read Delay (S) : auto
Write to Read Delay (D) : auto
Read to Read Delay (S) : auto
Read to Read Delay (D) : auto
Write to Write Delay (S) : auto
Write to Write Delay (D) : auto
Write to PRE Delay : auto
Read to PRE Delay : auto
PRE to PRE Delay : auto
ALL PRE to ACT Delay : auto
ALL PRE to REF Delay : auto
DRAM Static Read Control: Auto
Dram Read Training : Auto
MEM OC Charger : auto
Ai Clock Twister : auto
Transaction Booster : auto
PCIE Freq: 100
CPU volt:1.32500
CPU PLL Voltage: auto
NB Voltage: auto
DRAM Voltage: 2.10475v
FSB Termination Voltage: auto
SB Voltage: auto
SB 1.5 Voltage: auto
CPU GTL Reference 0 : auto
CPU GTL Reference 1 : auto
CPU GTL Reference 2 : auto
CPU GTL Reference 3 : auto
North Bridge GTL Reference : AUTO
North Bridge DDR Reference : AUTO
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Enabled
CPU TM Function: Disabled
Execute Disable Bit: Enabled
Load-Line Calibration: enabled
CPU Spread Spectrum: Disabled
__________________
System
Vista Ultimate 64
Antec Twelve Hundred Black ATX Full Tower Computer Case
Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM SATA
ASUS Maximus II Formula
Intel Core 2 Duo E8400 Wolfdale 3.0GHz co
ZALMAN CNPS9700 LED
DIAMOND Radeon HD 4870 1GB
CORSAIR Dominator 4GB (4 x 1GB) DDR2 1066 (PC2 8500)
Sound Blaster X-Fi XtremeGamer Fatal1ty Pro Series
Logitech G9 Laser Gaming Mouse
Razer Lycosa Gaming Keyboard
SAMSUNG T240 24" 5ms HDMI Widescreen
Mine after settings
FSB Frequency: 424
NB Clock Skew: auto
DRAM Freq: DDR2 1357mhz
CAS# Latency : 5
RAS# Precharge : 5
PCIE Freq: 100
CPU volt:1.32500
NB Voltage: auto
SB Voltage: auto
__________________
