It has absolutely nothing to do with the Trans Piper
I have my Transpiper modded... milled out the center ridge in the middle of the transpiper joining block and ran the heatpipe attached to the PWM through the middle. It gets more contact with the 2 heat pipes leading off to the finned part and with the two cases ive used (Antec p182 and Silverstone TJ09 it lines it right up to sit behind the 120mm rear exhaust fan. Works very well, During torture i can feel the transpiper get warm to the touch.
I wasn't able to to any comparative temperature tests between the two configurations but I definitely like the mod :up:
Oh and I went and cannibalized an old cpu cooler and took its 60mm fan... didn't have enough room to mount it on the PWM but i have it zip tied in blowing air on to the chipset, temps dropped 6 oC under load on the chipset :up:
let's see a pic... i thought you mounted something by the IO plate... the transpiper and non- versions differ in that area as the transpiper version has a gap between some of the fins on the HS over the PWM, whereas the non- does not.
what you mean? i have some 60mm fans myself, and i think even a 50mm... :)
BE, what's with the video link in your sig... you should at least hyperlink it so it shows what i'm clicking on!! :) I was expecting dancing monkeys, then was quickly disappointed. :D
stole it off an old Thermaltake Volcano 6 Cu
http://www.thermaltakeusa.com/2005/c...o/si/a1139.htm
Fan Dimension
60x60x25 mm
- and the reason it wont fit on my PWM is because the rear 120mm exhaust fan its about 15mm above the PWM blocking about 1/4 of the area closest to the IO plate. And my TRUE is mounted to blow air up... so the side of the heatsink is too close to PWM to fit it in... Wish I had a camera handy to show you, but I don't. The only way I could do it is either get a vertical blower fan or mount the TRUE in the other configuration and not have a pull fan on it. :rolleyes:
D.F.I LanParty UT P35 T2R ~Bios Chips~ are in!!! For those of you who have purchased them I will contact you through PM and those of you that are interested in a Back Up "8MB" Bios Chip for you're D.F.I P35 T2R .....Please contact me through PM I have 9/13/07 Official & 10/5/07 Beta:D ....Hurry :sonic: Going>>>>>>>>>>>Fast!!!!!!:dammit: :sonic:
i will purchase from you when i get paid from my side job....
Hello guys! Like I mentioned earlier I got the new MB... give it a test today and I'm BACK to " 0 "........! Same problem all over again... C1....
:mad:
Placed the CPU and CPU cooler, Memory, Video card connected it all with the power supply and again back where I was 2 weeks ago! I'm sooo frustuated now...
Here I uploaded a video:
http://66.49.240.122/M2U01013.MPG
Please let me know if you want me to record any specific place to make sure I got it right!
Ok I have a extra PSU which is this one:
http://www.newegg.com/Product/Produc...ake%2b430W
But the problem is that the connector for the CPU is 8 pin and on this one I only have a 6 pin one... how can I make it work? And just please don't tell me I need to buy another PSU after spending all those money on the one I have and If only if I was to order a new one and same thing happened I seriously will not know what to do and just... AHHH!
Ya there is also a 4 pin connector... well should I just try to start it with the 24 pin connector in and not connecting anything to the 8?...
God I hope I don't blow it up for grand finale!
Ok I connected the 24 pin on the other PSU and connected the 4 pin closest to the CPU and give it a try... it says error code 88 now... and it shuts down again?! Whats code 88?
I would like to clear up a few issues about this board that I am having.
First off, if I run Speedfan my computer locks up during the initial scan at the applications startup. My computer ALWAYS locks up at this point...
"unknown Winbond2=$9249 ID=$00 on SMBus at $22"
Second... When I try to run Intel TAT the program fails to load. But it doesn't lock up my system. This is the error that I get...
"error enumerating on demand clock modulation support
Terminating tool"
Third... Another thing that I find odd is that I can't run with more than 3GB of memory. 1GB x 3 sticks. When I put the 4th stick in, my computer doesn't post. The diagnostic LED (from what I have been able to read off the internet) shows that there is a memory issue. The error code seems to be very vague. Yet my memory passes memtest for 18hrs straight.
This is the memory that I have. With the HS that the memory has, I'm unable to verify what chips they are.
http://www.newegg.com/Product/Produc...82E16820178167
Forth... I can't seem to overclock my Q6700 for :banana::banana::banana::banana:. I used the quad core versiom of Prime95 25.5. At stock speeds I pass with flying colors. But if I try to bump the speed up just a hair, my system will not pass. I tried a combination of high fsb, low multi and low fsb, high multi... as well as everything in-between. Nothing seemed to be stable.
I tried this chip out in a ASUS P5K Deluxe and I had WAY better results. If anyone with a 2.9-3.2Ghz overclock on air could take screen shots of their bios settings, that may help me out in determining what settings I need to adjust. I gave it a few hours on my own, but was not able to get this rig stable. My temps aren't too crazy, I run a thermalright ultra 120.
OS = XP32 SP2 w/All Updates Applied
Bios = s.m.a.r.t (disabled)
Why use speed fan? And did you read the thread like I suggested its not a board for the faint hearted and theres a serious learning curve even for the most Advanced users I hope you are aware of that:welcome:
Here have a look for you're self......http://www.phoenix.com/NR/rdonlyres/...0/postcode.pdf
I agree with Solarfall this board is very nice.
I have been playing with the 1019 BETA BIOS & despite loosing maybe 50 or so mb/s & 1ns of latency in Everest over 1005 it has played flawlessly & given me marginally better & very consistent 3D benchmark scores both for 24/7 & benching.
This BIOS IMO is very stable & definitely worth playing with if your into that sort of thing ;)
Here is where I am 24/7 stable with 1019 if anyones interested.
DFI LANPARTY UT P35-T2R (BIOS 1019)
INTEL CORE 2 DUO QUAD Q6600 KENTSFIELD 2.4GHZ 4M L2 CACHE
OCZ PC2-8500 SLI 2 x 1GB PN:OCZN1066SR2GK
INNO3D 8800GTS 320MB (163.71 DRIVERS OVERCLOCK 617 X 955)
4 X HITACHI DJ 80GB HD'S (RAID 0 / 64K STRIPE)
SONY DUAL LAYER DVD RW (DRU-820A)
OCZ GAMEXTREAM 1010W PSU
WINDOWS XP PRO SP2
CPU COOLING: D-TEK FUSION + PA120.3 + D5 VARIO
PRIME95 + 3DMARK2001SE + 3x CPU-Z:(SCORE 64156)Code:>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Disabled
Virtualization Technology........... - Disabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Disabled
>Clock Setting Fine Delay Press Enter:
Ch1 Clock Crossing Setting......... - More Aggressive
DIMM1 Clock Fine Delay............. - Current[TBC]
DIMM2 Clock Fine Delay............. - Current[TBC]
Ch1 ControlFine Delay.............. - Current[TBC]
Ch2 Clock Crossing Setting......... - More Aggressive
DIMM3 Clock Fine Delay............. - Current[TBC]
DIMM4 Clock Fine Delay............. - Current[TBC]
Ch2 ControlFine Delay.............. - Current[TBC]
Ch1 Ch2 Common Clock Setting....... - More Aggressive
Ch1 RDCAS GNT-Chip Delay........... - Auto
Ch1 WRCAS GNT-Chip Delay........... - Auto
Ch1 Command To CS Delay............ - Auto
Ch2 RDCAS GNT-Chip Delay........... - Auto
Ch2 WRCAS GNT-Chip Delay........... - Auto
Ch2 Command To CS Delay............ - Auto
CAS Latency Time (tCL).............. - 5
RAS# to CAS# Delay (tRCD)........... - 5
RAS# Precharge (tRP)................ - 5
Precharge Delay (tRAS).............. - 10
All Precharge to Act................ - 5
REF to ACT Delay (tRFC)............. - 26
Performance Level................... - 6
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In.......... - Auto
Channel 1 Phase 1 Pull-In.......... - Auto
Channel 1 Phase 2 Pull-In.......... - Auto
Channel 1 Phase 3 Pull-In.......... - Auto
Channel 1 Phase 4 Pull-In.......... - Auto
Channel 2 Phase 0 Pull-In.......... - Auto
Channel 2 Phase 1 Pull-In.......... - Auto
Channel 2 Phase 2 Pull-In.......... - Auto
Channel 2 Phase 3 Pull-In.......... - Auto
Channel 2 Phase 4 Pull-In.......... - Auto
MCH ODT Latency..................... - Auto
Write to PRE Delay (tWR)............ - 14
Rank Write to Read (tWTR)........... - 11
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - 8
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
Read CAS# Precharge (tRTP).......... - 4
ALL PRE to Refresh.................. - 5
>Voltage Settings:
CPU VID Control..................... - 1.52500v
CPU VID Special Add................. - Auto
DRAM Voltage Control................ - 2.27v
SB 1.05V Voltage.................... - 1.070v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.61v
CPU VTT Voltage..................... - 1.60v
Vcore Droop Control................. - Disabled
Clockgen Voltage Control............ - 3.45v
GTL+ Buffers Strength............... - Weak
Host Slew Rate...................... - Weak
GTL REF Voltage Control............. - Disable
CPU GTL1/3 REF Volt................. - 115
CPU GTL 0/2 REF Volt................ - 115
North Bridge GTL REF Volt........... - 115
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
CLOCK VC0 divider................... - Auto
CPU Clock Ratio Unlock.............. - Enabled
CPU Clock Ratio..................... - 8
Target CPU Clock.................... - 3800MHz
CPU Clock........................... - 475
Boot Up Clock....................... - 265
DRAM Speed.......................... - 266/667
Target DRAM Speed................... - 1191MHz
PCIE Clock.......................... - 100mhz
PCIE Slot Config.................... - 1X 1X
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
SATA Spread Spectrum................ - Disabled
http://i106.photobucket.com/albums/m...S/3DMARK01.jpg
3DMARK2003:(SCORE 38319)
http://i106.photobucket.com/albums/m...S/3DMARK03.jpg
3DMARK2005:(SCORE 20090)
http://i106.photobucket.com/albums/m...S/3DMARK05.jpg
3DMARK2006:(SCORE 12286)
http://i106.photobucket.com/albums/m...S/3DMARK06.jpg
AQUAMARK 3:(SCORE 211,451)
http://i106.photobucket.com/albums/m...S/Aquamark.jpg
SHORT DESCRIPTION:
475 x 8 = 3.8GHZ @ 1.5250v
5-5-5-10 2T @ 2.270V DDR 1191
