my board does 300 MHz FSB without mods, i think the problem isn't the motherboard, it should be something else..
I don't hope this is final on air :)
Originally Posted by s7e9h3n
Actually I also need more explanation on that Tcore mod, I don't really understand it
Super Clocks Gamer!!! What is the actual VCORE? As CPU-Z is not right, I guess.
1.5v in bios.
I just love this cpu :)
the Max. Stabil.. I am not SuperPi Freak ;)Quote:
Originally Posted by Gamer
my aopen have no Mods!!!!
Did the kyosen's tcore mod....Its not pretty, but I hope it will brings peace to mobo and cascade:)
Thanks kyosen:toast:
http://img148.imageshack.us/img148/8282/1tcore39su.jpg
I still dont know why people are doing that mod .. respect but hey.. i can boot all the way up to -190 :D without any problems.
Most of the time mine can't post @-9C evap temp.:(Quote:
Originally Posted by Waus-mod
Can't have it all:)
Well i have the strangest thing ever in my life :P i can boot all the way with full ln2.. but no acces to bios haha.. then it need to warm up to -50 or higher. but booting aint no problem :D
gamer mount that prom of ure :D , and lets see what the hell happent to that thing @ jort's :banana:
At which page ar the Vmods ....BUT...clear job..i mean clear photos..:D
http://www.xtremesystems.org/forums/...ad.php?t=95411Quote:
Originally Posted by GoriLLakoS
Dumo:
Did it help?
Can you mark the solder points please, I like clean and understandable pictures of vmods, it is not like you are playing with lego :D
There is 17K Ohm between R570 and pin #1 of that winbond chip? And 33K Ohm between it and L46 (ground)?
hey aopen dudes! we need well.. i :D need compability/support for the Areca arc-1210 sataII raid controller.. please?!? :)
It worked:toast: ..Vcore temp. in bios stays @ 11C air or phase:toast:
Now I can boot straight to 240 from bios:) then remote control will take care the rest:)
http://img77.imageshack.us/img77/951...shot0440ex.jpg
Like kyosen said...set white and grey wire @17k before solder it to board..
http://img359.imageshack.us/img359/7374/tcore3ys.jpg
This should work :cool: . Using original resistor + 20K Vr, no need to cut trace. We'll see if it does work @ -80C - the 2600 just arrived :D
EDIT: Sorry about the ugly soldering job.....
Honey...... where is my remote???:( Dayumn... I forget where I put that thing....I need to overclock NOW:)
Found it...Heres a bit oot. with single 1900xtx@690/800..
http://img148.imageshack.us/img148/2...shot0485mx.jpg
http://img113.imageshack.us/img113/4...shot0494wi.jpg
what cooling ?
great result !!
Looks good Dumo, is that ss or more???
Have you ever compared your ES to your retail?
Gamer where are youre results :D
It appears that Yonah has only a slight performance edge over X2 on similar clocks, closer than one would expect from the PI scores. If the chip cannot run past 3.6ghz on xtreme cooling I think it will only be a match for a good FX-60. I'll be testing very soon.
http://home.arcor.de/jodee2/aquamark141kYonah.JPG
Core Duo T2600 @ 3300 MHz
7900 GTX @ default
Wow, nice score!
OK...I can verify now that this mod works on air...it allows temp adjustment while in bios :woot:Quote:
