Hi Ket (and others),
I am in need of some serious help on my P5Q Pro!
OK, here's my story, I setup my system about a week ago:
Antec P160W incl. 1xFront / 1xBack (Antec Tri-Cool Blue @ 79 CFM)
OCZ ModStream Pro 700W
ASUS P5Q Pro
Intel Q6600 G0 SLACR
TRUE incl. 1xPush / 1xPull (Noctua NF-P12-1300 @ 55 CFM)
Corsair PC2-8500 Domainator 2x2GB w/ CrossFlow Fan
Sapphire Radeon HD 4870 1GB
1xLG DVD-RW
1xSeagate 320GB OS
2xSeagate 500GB RAID0 Storage
When I setup my board, I set it up stock speeds, and right away flashed up to 1613. I prepared for the arrival by downloading all of my necessary drivers and BIOS flases on my main system -- this is going to be my saweetness gaming machine :D!
After the flash I made a successful OC to 333x9 for 3.0GHz, not a bad bump, but I've had more on these chips before (I've sold several PCs to friends always with ASUS boards). Tested OK with Memtestx86. With such a light clock, I installed my licensed copy of Vista x64 Ultimate, and got my system running great (games n' all). After in Windows, OCCT tested OK.
I decided to start playing more to try to get it up to 3.4GHz - 3.6GHz. For the life of me, I couldn't even get the board up to 366, the board would not POST (blank screen fans running and no BIOS beeps). A CMOS clear always fixed it. I know enough to keep the dividers matching up, and my memory at 1066 as it is rated. I also know enough to set the voltages: starting at 1.350 and working up to 1.425 for VCore, 2.00 and 2.10 for VDimm, and 1.3 to 1.4 for NB. Oh, and my memory timings of 5-5-5-15 for 1066.
I reset to defaults and flashed back to 1406 without any problems at all (using the KodaKey tool at its latest ver of 0.72), and played around very briefly but stuck at 333x9 for 3.0GHz. Reason being is that I was reading up online and found Ket's 1406 Modded BIOS and wanted to try it!
I reset to defaults and flashed to the 1406 Modded BIOS, and now have a blank screen with no POST again! This is on the reboot right after the flash.
I read, acknowledged, and followed the instructions from Ket:
Sometimes happens. The risk in using any of these mBIOSes is the same as flashing to a new official version. So heres some basic steps to take;
1. Set your system back to stock prior to flashing
If your system does not POST on restart;
2. Clear CMOS by removing battery and power cord, remember to set CMOS jumper to "clear" as well.
Tried those, my system still will not POST
Chances are the flash went wrong. Grab a floppy disk (doesn't need to be bootable) and put a known "good" BIOS on the floppy. Rename the BIOS file to AMIBOOT.ROM, hit the reset button and the system will read the floppy disk and automatically restore the BIOS with the one on the floppy disk. The system will restart a few times and before you know it you will be looking at the POST screen again.
So to confirm, last night, the PC sat without a battery and power cord (I held the power button until the lights went out on it) for 8 hours. Still no POST afterwards. I dropped my 1406.ROM renamed to AMIBOOT.ROM onto a floppy disk. The system does not read the floppy disk at any point during POST, not even if I hit the reset button, or hold the reset button until PWR goes out. I tried dropping the AMIBOOT.ROM onto an empty flash stick, same thing. A last ditch effort, I made a bootable floppy, dropped MiniDOS / AFUDOS / AMIBOOT.ROM and a custom AUTOEXEC.BAT onto the floppy to try. No go! Desperate, I even tried a different floppy drive, floppy cable, and a different PSU connector!
Oh, during system startup, I also tried to force a flash using CTRL-HOME without luck. I think that I am fubar'd! I have been working and building PCs for 10 years, I've never screwed up a BIOS flash on anything, let alone my own equipment (heck I ran a custom BIOS on my MSI Neo2 Platinum and DFI NF4 SLI-DR Expert)!
My PC won't boot, what do I do? HELP, PLEASE!
YES, I know I am asking for a Miracle ;) :p:! I don't want to return for RMA and wait for 4 weeks......argh!
Thank You,
Jonathan
Technical Writer for LAN Addict!
Informations Technology Agent for Zycom Technology Inc.
Let's face the obvious. Yesterday we were nerds. Today we're the cognitive elite. Let's conquer. - Chester G. Edwards
