thats prity sweet :)
http://img826.imageshack.us/img826/7493/smdscn0521.jpg
Went to a new chassis & power supply. I'm actually a little disappointed since the chassis doesn't fit together perfectly (Lian-Li PC-K58W) and the new CPU heatsink (CM Hyper 212+) had a bad fan. Also, please forgive the messy CPU fan cable (I've got that neatened up a bit now). I have to see if I can't get that SATA cable (for the optical drive) routed properly. I'll be hiding the LED headers, too, since I run my computer as unlit as possible.
Nice, but rember this:
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
That monster's bigger than I thought :D
Holy crap, I too thought "mmh nice case", then I saw the last picture. :O
It's a mansize maneater. :D
HTPC :)
http://www.pohrani.com/t/H/7w/2PF2mnVX/dscf7902.jpg http://www.pohrani.com/t/c/T5/3rutcNNC/dscf7913.jpg http://www.pohrani.com/t/1h/kI/3VAGDC9c/dscf7890.jpg http://www.pohrani.com/t/3P/FD/3zIDMtqB/dscf7919.jpg
AMD BE-2350
Gigabyte MA78GM-S2H
2Gb DDR2 Kingston
250Gb Seagate single plate
Hyper HPU-4S525 modded :)
A+ CS-GL3
ATI Remote Wonder
Now waiting for Scythe Mini Ninja and AC 120mm PWM fan to arrive
Good job Pupo.
Is it loud too much?
http://img577.imageshack.us/img577/4611/smdscn0515.jpg
The chassis isn't that dirty anymore, but that's a slightly newer picture (I think?) of the computer at its honorary place under my desk. The marks are flash anomalies. That said, I'm not entirely happy with the chassis as, while it's more solid than the old chassis, it doesn't fit together like I'd expect a Lian-Li to. You can see gray steel at the edges of the side panels (that's the main chassis--not the side panel) and the plastic work is also poorly done--with a millimeter of overhang.
My current setup:
http://koti.mbnet.fi/ipe91/antec300/DSC_0635s.jpg
http://koti.mbnet.fi/ipe91/antec300/DSC_0636s.jpg
Didn't bother too much cable management etc.
http://koti.mbnet.fi/ipe91/antec300/DSC_0638s.jpg
http://koti.mbnet.fi/ipe91/antec300/DSC_0639s.jpg
Just to show how tubing and fans cables are connected.
Yes that's phobyas 1080mm rad! or 9x120mm :]
Why is there a need for a exhaust fan there?
Very Clean, i like it :D
Good choice on the mouse, i love my Mamba :)
for some reason the top mounted PSU is realy disorientating in the second pic :) lol... i like it though
I see what you mean, i think it is because there is no 5.1/4" drive bays as well.
probly :) its a good pic though
This is my favorite case, Oh look, it comes with a decorative little midget.
Installation:
1. Rent crane
2. Place midget aside
3. Remove roof of house.
When I saw the work log some time ago, I thought this case was going to be too big for comfort, glad to see I was wrong.
Do not quote pics -.-
