E1200 Dual Core Celeron 1.60Ghz @ 3.00Ghz
Hey everybody,
I overclocked my E1200 Dual Core Celeron 1.60Ghz @3.00Ghz these BIOS settings. Also, I tried to oc with @2.50ghz, @2.80Ghz, @3.20Ghz and I was successful with these speeds at that time too (I was use different settings for only @3.20Ghz). However, I tried to different BIOS setting variations for @3.40Ghz and then I was failure at that time. I couldnt reach @3.40Ghz at that time. Anyway, I can use it daily with @3.00Ghz and @3.20Ghz todays.
Everyone can give some advise for reach @3.40Ghz lol :)
BTW, I didnt add my screenshots or my valid values for cpuz yet but if u wanna them all, I can share for u of course.
Here we goes,
Code:
377FSB Dual Core Celeron BIOS Settings (907)
CPU Feature
Ai Overclock Tuner [Manual]
CPU Ratio Control [Manual]
Ratio CMOS Setting: [8]
FSB Frequency [377]
FSB Strap to North Bridge [Auto]
PCIE Frequency [100]
DRAM Settings
DRAM Frequency [Auto]
DRAM Command Rate [Auto]
DRAM Timing Control [Auto]
DRAM Static Read Control [Disabled]
Ai Clock Twister [Strong]
Transaction Booster [Enabled]
Boost Level [0]
Voltage Settings
CPU Voltage [Auto]
CPU PLL Voltage [Auto]
North Bridge Voltage [Auto]
DRAM Voltage [Auto]
FSB Termination Voltage [Auto]
South Bridge Voltage [Auto]
Loadline Calibration [Enabled]
CPU GTL Reference [0.63x]
North Bridge GTL Reference [0.67x]
DDR2 Channel A REF Voltage [Auto]
DDR2 Channel B REF Voltage [Auto]
DDR2 Controller REF Voltage [DDR2_REF]
SB 1.5V Voltage [Auto]
Note: English is not my first language... So sometimes I am not able to express myself properly... When I writes something in English, I can mix my own grammar in it so sometimes it sounds a little different to you. Really sorry but that
System Specs
Temperatures: 10 C between 23 C normal
Ram: OCZ Reaper 2Gb 800 Mhz Cl4 Kit (2x1gb) (With Heat Pipe Cooling)
Processor: Intel Celeron Dual Core E1200, 1.60 Ghz, LGA775 512k L2 Cache 800Mhz FSB - Cooling: Zalman Reserator XT
Motherboard: Asus Maximus Formula - x38+ICH9R - Rev1.xx
Graphics Card: GeForce 8600 GT - 256Mb 128bit GDDR3 - GPU Clock 540Mhz - RAMDAC 400Mhz
Hard Drives: 80Gb Maxtor, 160Gb Seagate, 320Gb Samsung
POWER SUPPLY: CM Real Power Pro 620w
Case: CM Stacker 831 Black
