hi guys; someone use teamgroup elite pc6400 2x2gb on this mobo? if yes, how they works?
I have problem to find stability with these ram on my UD3R
has anyone gotten this annoying thing with et6,i even uninstalled et6 and in stalled the newer version still pops up every reboot.even if i set et6 not to start on sartup when i go to manually stat the app i get this.http://i40.tinypic.com/5xvfpz.jpg
I get bootloops with my Corsair DHX PC2-8500 (2x2GB) - the G.Skill PI Black fails to POST and just beeps continuously. I am considering RMA'ing the board, the question is if I should get a replacement UD3P or just choose a different board, like an ASUS or DFI.
Also I know the RAM is not bad because it works great in my Rampage Formula board.
Wow, I'm only on Page 1 of this thread...and it's very good...
I'm about to get this UD3P MB, and I already have an E8400. I have some learning to do before going for any significant OC's with it... ( where are my reading glasses...)
Sorry, where do you get the beta bios?
Anybody running F6 on the UD3R? Have you noticed a difference and if so what? Thanks.
I loaded f6 yesterday. No difference for me, as my issue with ram slots is still present. I emailed tech support at gigabyte and waiting a response.
this ET6 update thing is driving me mad!now i wish i hadnt updated the bios.
Isn't there also a updated version of ET6 that came out about 2 weeks ago?
bluestang,i never had this problem before.it all started when i flashed to F8a bios. once i rebooted i got this annoying little message say that my gigabyte application has found an update and i need to go to the gigabyte website and update it.well i downloade the newest version of ET6 and tried doing an update install but got wierd erros.so i uninstall the old one and installed the new one,but it still keeps popping up after every boot.
Wont do you reflash to F7, F8A is a beta anyway, then wait till f8 is a final bios.
thats what im going to do,i just sucks cause i have only flashed the board once before this from F4 to F5.and i onlyflashed it again cause i thought it would be better for quad OCing.oh well f7 here i come.well heres my latest.still trying to get higher.http://i41.tinypic.com/20sg80o.jpg
Hi ,Anyone can hit 550x8 FSB orthos blend stable. Share your setting Pls. I hope to do this for a long time.Thks :D
I have done 550x7 with my E8400 C0 (canīt do 550x8 with it) not blend thou but 32M and 50 loop LinX. I hope my screenie can help you some.
http://i282.photobucket.com/albums/k...11005551-1.jpg
i would but im nit thar good with the software side of things.i dont even have the slightest clue as to where it would be to turn it off?
Thanks bro, what Cpu are you using my E8600 doesn't like cpu ref below 0.76
I try higher than 0.76 now.
Thanks ghostleader ,may be yr RAM can do 550 properly. I just got new Crucial 2x2 GB kits that can do 600 mhz (ddr-1200) I try the setting like your before but not success. Do you think Cpu reff need to adjust? I never touch it
Has anyone used a Scythe Infinity cooler on the UD3R or UD3P? If so, any problems fitting it?
I cant wait to try an E8700 on this board.
