not yetQuote:
Originally Posted by Richard Dower
not yetQuote:
I'm happy with my current settings at 400x8 on my E6600... I really want 400x9 but it gets too hot atm :(
whats your temp and cooling with 400x8??Quote:
Originally Posted by eXceededgoku
temp is 33oC idle and around 45oC, at 1.47v after vDroop (this is on everest beta edition). It's a crappy week 24 so I need a lot of voltage to get any higher, cooling is an arctic cooling freezer 7 pro in my Antec P180.
temps with coretemp or others? if yes whats your ambient temp?Quote:
Seems all the even number DS3 bios's work best ;P
looking forward to F8 with the D9 Fix so I can push some 500 mhz actions
@all
Bios updates that will enable your Gigabyte 965 Mobos to support Core 2 Extreme Quad-Core CPU (Kentsfield) are out:http://www.gigabyte.com.tw/Support/M...BIOS_List.aspx
Dude Where Have You Been?????
You're about a day late and a dollar short!
anyone is having problem with DQ6 + X-Fi or Micron D9?
Please quote my post and reply here.
I'll send you the fix.:cool:
***F8***
***F8***
***F8***
Damn F7 didnt do anything for me and my crappy OCZ ram!!!!
Looks like I'll be off to Newegg. It sucks that the damn RAM prices
have gone through the frickin roof!!!!!!!
Originally Posted by SnakeEyes
there are so many choices for the same price out there, why OCZ??:confused:
Question guys. Im still on F4 for my DS3 and i havnt updated because im assuming if I do I'll need to go borrow some cheap ram again from Bestbuy. For those of you that cant boot at default ram voltage, does the voltage setting reset when you update the bios?
I just wish the DS3 would correctly detect my RAM as DDR2-800 instead of DDR2-667.
I'm using this GEIL RAM http://www.geilusa.com/proddetail.asp?linenumber=71
I'm pretty sure the new bios have better default voltages. I wouldn't worry about it.
oh no, I am not going to wait
coz I am going out soon.
here you go:
Flash it at your own risk.
It is a final release , not beta.
http://rapidshare.de/files/36534640/965pdq6.f6.html
1. fixed Creative X-Fi reinstallation problem;
2. improved Micron D9 overclocking performance. (I write this 2 as a summary, not by Gigabyte)
this should be ready in Taiwan server as well.
for the below F5f, I am not sure have anybody tried yet.
one more beta here, also fixed the X-Fi issue,
remember, flash it at your own risk.
http://rapidshare.de/files/36536658/965pdq6.f5f.html
Please feedback after you have tried the above 2 releases.
any DS3 action for us to test :)
sure, please be patient. :DQuote:
Originally Posted by Dazog
I updated my DQ6 to F6 but I am not sure it worked as POST screen, Everest and CPUID show F5, although I did have instability until I properly cleared DMI data and loaded Optimised Defaults. Back to 400x8 for the moment because it didn't seem to like 425. Now that it is booting into Windows and showing some stability, I'll try to 425 again. Using 'normal' for vCore.
Should I be reflashing or is the f5 vs f6 indicator because it is 'pre-release'?
guys please get the F6 from the official gigabyte site.Quote:
Originally Posted by GAM
Now folding dual cores (100% CPU) @ 425 / 3.4GHz.
I lashed out and bumped the vCore from 'Normal' to 1.425v and vDimm to +0.4v. Temps have jumped by about 5c, but I think I can drop the vaults a little once I've finished playing. I'd like to 450 FSB, stable. That would be sweet :D. (...enough for me for the mo ;)).
Still not sure whether I am truly running F6 though. I doubt it. :confused:
[edit: @laziepid, just saw your post (probably while I was posting), downloaded the 'official' version. About to reflash and try again. Will report back soon.]
Was in the midst of posting to advise that I was running FSB 438 @3.5GHz and running dual prime95 (small/large FFTs) when boinc. Restart! :doh:
@1.42v vCore (1.38v), temps were hitting 59c max on both cores (Everest) for the <10mins it lasted.
I've now reduced back to FSB435@3.48GHz(44412), stress testing... 5mins so far.
[edit: 60c now @ 28c ambient, upto Test 4.]
You simply can't read. That's all. There isn't any problem with your mobo concernicg RAM detection.Quote:
Originally Posted by therat
"The safe-mode SPD will be applied to all GeIL's DDR2 series product 667 & above with shipping date December 2nd, 2005 and beyond. You will find a "CAUTION" card in every retai packaged DDR2 products mentioned above. "
Anyone having more troubles with the latest F7 then they had before updating? Flashed yesterday and max overclock has deminshed :stick: I could boot 520x7 but now max is 500x7 though with better subtimings... Anyone else having these problems?
Btw I'm using the same kit as above, 1gb version for 115E or so at dutch online shop. Tell me what you can do with it, I'm rather stuck at max suicide shot off 531x7, lowering multi didn't help as well as running higher ratio's so I'm sure it's the ram. Though ddr1000 5-5-5-12 stable for 115E is good enough for a cheap kit, I wonder what others are doing with it?
Edit: after looking again I noticed I got the red heatspreaders... and their rated 5-5-5-12 pc6400 instead off 5-5-5-15.. sorry diffrent kit linkie..
Yep saw that on the Geil website, however it doesn't explain that when I manually set all the memory timings so that it should be DDR2-800 5-5-5-15, why every diagnostic program around detects the RAM as GEIL DDR2-667 PC2-5300. If the DS3 was correctly detecting it so would the diagnostics.Quote:
Originally Posted by mach82
cheers
