I think it should be negative values for quad cores, between 60% and 63% of reference voltage seems to be the accepted range. If your VTT is in the region of 1.28-1.30V then playing with values between -20mV and -120mV should give better stability (-120mV would be about 58% of reference, -20mV would be 65% of reference approximately). I only adjust the one value for the data bus of the core that is failing, not all four values.
