the zipped files are invalid yo.
I have slightly odd problem with two Corsair CMX512-PC3500C2 (BH5). They are giving error on stressprime, superpi and etc on 230MHz 2-2-2-5 2T 3.3v. Max stable with 2-2-2-5 2T on 3.3v is 220MHz and yes, i have checked every posible setting in the bios. This problem is only in DC mode, when using just 1x512, both of them is working fine is SC (1x512) with ~250Mhz 2-2-2-5 1T 3.3v. So i cant decide is the problem in San Diego's memory control or is it in MSI NEO2 bios.
Does enyone else have this kind of problems with SD ja NEO2? :confused:
Hi need.for.mhz
Good job editing the bios did you do it yourself in the end or did tictac help you. Are you going to make a 1.8 version with those timings as well? Also i need someone to add the 1t force command so that the san diego will work with 1T without A64 tweaker.
; Command Rate(dcl)
cr_data equ 0EFFFFFFFh ; Command Rate (1bit)
cr_1t equ 000000000h ; 1T
cr_2t equ 010000000h ; 2T
If you could try to do this i would be really grateful as i dont really understand how to do it myself and tictac doesnt seem interested in doing it.
I can host any bios files for you if you want i have fast webspace and i can test bios files as well as i have a spare bios chip.
NFM nice job there... but those settings doesn't work for me... TCCD.
Good job tho... i wish i hav the time to take up some BIOS editing too....
thanks all, that bios work very good on my board
@sideffect
I did myself, finally started to understand bios structure. Give couple minutes and I will post v1.8 BIOS :toast: . unfortunely I can't use modbin6 to unhide hidden options :( Need Win 98 for that. Hang on
Why not use DOS and a floppy? That's how i unhide bios options etc...Quote:
Originally Posted by need.for.mhz
^^^ dude tell me more!!!!!!
so you make dos floppy ( right click A disk, format, choose make bootable dos diskatte?) then when you boot you call modbin6? I did that but it takes modbin forever to load the BIOS
Please tell me step by step because I'm ready to realese v1.8 bios with 1T fix for san diego, thanks
http://www.freewebs.com/tmod/utilities.htm
Download Tmod's Bios Mod v3.6 and click on it to create a bootable floppy. Then put the bios file onto a 2nd floppy (call it bios.bin). Boot with the Tmod floppy, then insert the 2nd floppy. Then press:
1 (enter)
2 bios (enter)
0 (enter)
Then mod the bios using modbin6 (its in the Tmod package) and save the bios (as bios2.bin for example) and exit modbin. Then press:
3 bios2 (enter)
Reboot and take your freshly modded bios from the floppy and post it here! ;)
link is ok, but winrar says that archive is broken. And the file is only 1.85kb
Can you host it?
I can host it if you want, pm me or msg me on aim
I need Tmod's Bios Mod v3.6 asap. Anybody have it PM me or post link
Go it!
Hehe
Wow i hope this 1t hack works. I can host whatever u need hosting and give u ftp access to so u can add other files.
emal = robertwillmin@hotmail.com also msn
Ok, here he is: v1.8 official modded BIOS with fix for San Diego CPUs. This is Rev.1. Taken from readme:
^^^ Includes memory optimizations.Quote:
- Based on v1.8F BIOS
*** This is a special San Diego Edition, therefore 1T Command Rate always will be enabled.
Will work on Platforms that are able to boot with 1T at default settings
Changelog:
- Fixed divider issue, trc = 12 clks & trfc = 18 clks on all dividers
- Read Write Queue Bypass = 16x
- Bypass Max = 7x
- Idle Cycle Limit = 256 clks
- Max Async Latency = 8ns
http://www.swjka.com/k8nneo2bios/?dir=./need.for.mhz grab it from here. THANKS TO SIDEEFFECT FOR HOSTING
EDIT: This BIOS was tested and it work great
I'm so ready for next release aka Rev.2
Bios will soon be tested :)
:toast:Quote:
Originally Posted by sideeffect
Haha guess what?
It only works :banana:
thanks so much mate. Im going to play around with it now :)
Added both your bios files to full rars and added them here
hehe, my pleasure. Thanks for hosting :cool: . Just wait for Rev.2 Try to play with your memory, see if you can clock them higher than before
Great bios there; does the 1.36 version have the same tweaks as the 1.8?
Sorry, don't have a copy of Tmods tools available here now, but i can get one to you tomorrow if no one else finds one first. :)
^^^ The only difference between my 1.8 and 1.36 is that 1.8 has 12 clock trc and 1.36 has 13 clock trc. Also 1.8 always boots with 1T command rate, other than that they have same tweaks. My 1.8 bios doesn't have unhidden options while 1.36 does. Provide me with Tmods, and I will revise both BIOS, so finally I'll be able to use modbin :)
Nice, having the opportunity to flash a modified Bios. But I would rather flash an new official one. Any Information about that? I heard, a Beta is in the Web, but this one is not that good?!
Need.for.mhz - did some rumaging around on my old utility backup cds, check your AIM e-mail ;)
The 1.9B5 is still crappy, I had endless problem with it including no POST, other people on different forums reported same issues. When newer beta will come, and if it will be more stable, I will mod right awayQuote:
Originally Posted by mapel110
Thanks CD 1986
I'm working on Rev.2 of my v1.8 and later I will try my v1.36
Thanks!
Great, looking forward to the final revisions. 1.8 & 1.36 are the only ones worth modding at this point. :)
Great work NFM this 1.8 san diego bios rocks :toast:
Havnt got enough time to fully test it tonight but it is definitely more stable than any of the other bios files i have used Including tictacs r2.
Gonna push it tommorow and see if i can hit 265htt 1:1 with this bios which is looking quite likely atm.
