i7 2600K L041C108
GA-P67A-UD7
Air (ambient 22C) - ZEROtherm ZT-10D Premium with Panaflo 120mm x 38mm Ultra High Speed
G.SKILL Ripjaws-X F3-12800CL9D-8GBXL
i7 2600K L041C108
GA-P67A-UD7
4th submission...
This SB runs 50x with BIOS PLL voltage overide set to disable and will boot/bench 55x.
Cooling: TRUE Black with push/pull.
Ambient temps ~ 2/3 C.
http://i695.photobucket.com/albums/v...HzLinXload.png
First entry and most likely last with this cpu :rolleyes: Some smoke is almost in air :D
MB: EVGA X58 sli
Watercooled, room temp ~20'c
CPU batch 3931A219
http://koti.mbnet.fi/~mobsters/xTreme/linx21.jpg
The testing for this club needs to have better rules so that all systems are tested equally.
HT ON vs HT OFF?
Sandry Bridge SP1 Linx AVX or older?
e8500 single stage
told ya i be back:yepp:
i'll be back when i play with some nice 920s:D
i might try to go a bit higher:eek:
Core i5-2500k 5.3Ghz everything is ok ?
http://www.abload.de/thumb/linxacebmwr.jpg
i7 2600K L042B243
Maximus IV Extreme 901 bios
4 GB G.SKILL Perfect Storm Model F3-17600CL8D-4GBPS
Swiftech's Apogee XT Swiftec MCP355/Laing DDC-2 w/XSPC Acrylic Reservoir
Thermochill PA120.2 Slipstream 110 cfm's
http://img695.imageshack.us/img695/7...435ghz15vl.jpg
not a very good batch does 4.8GHz linX stable at 1.4 though
@zsamz nice score buddy!!
Submission #5...
Cooling: Noctua NH-U12P with push/pull ambient temps were ~7/8C.
http://i695.photobucket.com/albums/v...hzLinXload.png
dragonhunter | 1.45 in bios | ASUS P8P67 Deluxe | WC | L042B243
http://img560.imageshack.us/img560/3714/5ghz.jpg
Good job! Don't set it on fire! :ROTF:
HT is already addressed. AVX is another thing, I'll think about it.
You haven't read the rules. :(
Your batch number isn't listed and your CPU frequency is too high! :D
You sure are addicted, man! Added both of yours. Keep up the good work! :up:
here is my submission before i sand this MB for replacement
cooling-water (ambient temps 77F)
batch#L040B671
http://img62.imageshack.us/img62/2115/x512133gflops.jpg
http://img189.imageshack.us/img189/6...superpi.th.jpg
Uploaded with ImageShack.us
hope i got it right this time lol
evga classified e760 /phase/3849b018
Make sure you guys use the latest Linpack, Intel released a new library set dated 2/3/11.
http://www.mediafire.com/?q2qkke5wfimxq2h
i7 2600K Batch: L045B005
Gigabyte p67a ud4
Custom Build SS
http://img690.imageshack.us/img690/5...1014257.th.jpg
http://img4.imageshack.us/img4/5052/...1020037.th.jpg
