any other pictures? Looks interesting.
Nice case game_matter i like it :up:.
Thanks a lot Oxygen!! I have a similar case and i want a Black&White color scheme, i never thought about painting those things! I was thinking of painting my PSU but decided against it, i will just sleeve it.
Check out ChilledPC they have these white slot covers for unused PCI, memory, PCI-e sockets:up: You also have the same problem i do, colorific Gigabyte board that ruins it:ROTF:
Started my build:
Sugo SG05B
Phenom 900E @1.15v
Sammy 1TB
4850 - Getting Cooler with rear exhaust.
4GB
Asus AM3 ITX
Can't stand the noise of the PSU fan so I took it out.
http://img685.imageshack.us/img685/1...000093h.th.jpg
Opteron heatsink modded and placed a 120mm Yate. Thinking about a 140mm.
http://img254.imageshack.us/img254/3...000095j.th.jpg
If I had the time there's enough space to mod the PSU to the front.
http://img837.imageshack.us/img837/6...000096o.th.jpg
my NZXT Phantom:D
New Camera- New and better Pix :up:
GE-X5 14.1MP 15X Optical Zoom
8Pin Cable
http://cbiwebhost.com/pix/images/ocau/pc/CPU-Block.JPG
Downstairs
http://cbiwebhost.com/pix/images/oca...own-stairs.JPG
Overview Top-Half - Need to clean my Radiator :(
http://cbiwebhost.com/pix/images/ocau/pc/Top-side.JPG
Backside Spaghetti
http://cbiwebhost.com/pix/images/ocau/pc/backside
Overall Shot, Cat interested :lol:
http://cbiwebhost.com/pix/images/oca...verall-cat.JPG
Some ridiculously wide images here, Doctor Freak posted 2576x1952 and oxygen200000 1552x1849 (and transit921 even quoted that!!). Also MagicSpectre put three images side by side..
Originally Posted by Rules
Well here's my build as it stands.... gotta bust out the real camera and take some quality pics... so here goes the cellphone teasers!
http://sphotos.ak.fbcdn.net/hphotos-..._3954040_n.jpg
and turned on...
http://sphotos.ak.fbcdn.net/hphotos-...1_399782_n.jpg
Case is a Corsair 800D
Thatīs a long way down jejeje.
Looks nice :)
@Chaos, hows the FrozenQ res working for you? is the LED too bright? I almost bought it for my current build but I was little concern that it might be too bright.
Pretty clean build btw :up:
@ Batiatus
I love that white/red look. The window and the case look so nice with the clean internals. Good job!
God please forgive me for coloring WC loop red.:D:owned::dammit:
http://www.shrani.si/f/2U/Ni/30ysfduv/15072010232.jpg
http://www.shrani.si/f/J/T1/2sMTQOM/14092010316.jpg
http://www.shrani.si/f/5/TW/3cIyTcjg/14092010318.jpg
Pictures actually don't do the FrozenQ res justice, the actual look of it in person is just amazing. The UV cathode in the center isn't too bright at all, you just see a faint purple line, depending on what color your double helix is that is predominantly what you see.
I am really in love with this res haha, I got the 250mm res if you were wondering.. A little tricky to get in (Obsidian 800D loaded) if you run SLI/CrossfireX and liquid cooling, but its well worth the time to get it to work!
http://sphotos.ak.fbcdn.net/hphotos-..._3340836_n.jpg
Pic does a little more justice to the actual quality of the res.
A bit tough though cutting the side panel, the metal sheet is pretty thick. Its not perfect but Im just glad that it came out fairly decent.
Now you got me thinking ... Its a little pricy but it's probably worth a shot. ThanksQuote:
Just having a bit of a trawl through as i haven't looked for a while.
I love what you have done here. i'm a big fan of the Skeleton case and have completed a few builds and mods with it. your work shares the same "everything on show" ethos that I like. You say you're doing an asthetic upgrade. Might be worth seeing how it looks without the anti kink coils. might make it look cleaner. Might make it look not so good, woth a look though. Please post new pics if you have them.
My media server before I took it down to be upgraded. Hope to have the rebuild done by the end of month.
http://hostthenpost.org/uploads/f31e...6de834026f.jpg
http://hostthenpost.org/uploads/b376...58c24c156d.jpg
hi guys,
finally I've finished my rig with peltier cells, and I must to say that i have obtained very good results (-9 idle, -5 full)
here's some photos:
http://i51.tinypic.com/2rp7ght.jpg
http://i53.tinypic.com/3163wvq.jpg
http://i56.tinypic.com/dvokma.jpg
I just looked pics on all pages and there are some really nice cases :) Well done!
Here's mine...
http://imgur.com/p67Ez.jpg
http://imgur.com/2ljR7.jpg
http://imgur.com/pwBYz.jpg
http://imgur.com/jOegP.jpg
Midrange system:
CPU AMD Athlon II X4 635 2.90GHz skt AM3 box C3
MOBO Gigabyte GA-890GPA-UD3H
RAM Kingston HyperX XMP 4GB DDR3 1600MHz
VGA Sapphire Radeon HD6850 1GB DDR5 256-bit
Cooler Prolimatech Megahalems rev. B
HDD Western Digital 1TB SATA-III Black
Case CoolerMaster HAF 912 Plus
PSU Gigabyte ODIN Pro 800W
DVDw LG GH22NS50 bulk black
FAN Xilence XP-F120.R
http://www.mygarage.ro/attachments/m...s-img_0020.jpg
http://www.mygarage.ro/attachments/m...s-img_0021.jpg
http://www.mygarage.ro/attachments/m...s-img_0026.jpg
http://www.mygarage.ro/attachments/m...-img_0007a.jpg
