Problem with Corsair Twin2x2048-6400 (CL5) Manual setting
Hi guys,
I really need your help here.
I'm UNABLE to set the RAM setting at MANUAL at the rated timing (5-5-5-12)
basically i fail memtest.
If the settings are set to SPD i'm passing memtest. when continuing to boot into winXP , CPUZ shows 5-5-5-18.
I'm NOT overclocking in any way, everythign is on AUTO.
All the Voltage settings i have are set to AUTO, except the RAM which i set to 1.9V which is the Rated voltage for this pair per corsair datasheet.
i tried raising volatege up to 2.1v and didnt help. also tried disabling Legacy USB (as was suggested somewhere).
even trying to set 5-5-5-18 manually fials memtset at some point.
I'm quite desprate on this issue, i replaced my pair and still same thing.:confused:
If someone have this Corsair pair and was able top PASS memtest after he switched to manual settings, PLEASE post ALL the BIOS SETUP, or just LOAD the BIOS file here so i can try it myself
My H/W is as follows:
M.B : P5B Deluxe (non wifi)Bios 0711 and now 0804.
RAM : Twin2X2048-6400 (XMS6405v5.1 modules) (this is the CL5 modules)
Video : Gigabyte 6600GT
HDD: Seagate 250GB 16 Mb cache SATA-II
PSU : JSP-tech EZ-COOL 420W
