Originally Posted by uniacid
guys I need some emergency help, last night I tried some settings that worked the week before but suddenly this week my pc has been acting funny, not allowing me to overclock much on settings I've ran before and I've been having to reset my cmos if that happens, so last night I decided I would try again to see if it would work and right around 2.4ish I get no post from my pc and attempt to reset the cmos only this time even after resetting my cmos I get no post at all, I've checked my psu's (not sure about them as they turn on automatically once they get power) and I've stripped apart my pc today and put it back together only connecting the essentials and it still does the same thing, psu turns on automatically, shut it off manually via case switch then I turn it on properly via the case switch yet no post, also from the D-Bracket it shows that it is "Decompressing BIOS image to RAM for fast booting".
So I come to you guys for help, is there anything you can think of to try or what the problem could be and why this is happening? :confused: :bsod:
THANKS A BUNCH!
