You know that p95 blend is not maxing out the temps.
Try LinX AVX max memory and then :)
I know that is why I'm doing Prime instead of LinX for the initial test.
As of this moment LinX gives me 95c in 1.2 sec. lol
But I'm in the process of lowering the temp.
And last night I made it about 8-10c lower and kept stable for 30min or so. (didn't have enough time, it was late last night night...)
I'll try some more later tonight and I think I can get there and try LinX if it's successful after prime run.
Ket appreciate the effort ;) You've done plenty for ASRock owners. Again it really doesn't bother me since I don't run a stock system anyhow. The current hardware does quite a nice job. But for someone who plugs & plays on a default/stock system, it will effect them. Especially if they compare it to another competing board at default settings. I also asked the 3rd person I know with the same board to perform the same test. I'll report back my finding on that also.
Brian
Update. The third guy I spoke of also had the same results. He is also using v1.80 UEFI and loaded all default settings and a 2500K.
I'm with 2600K 1.4v for 4.8GHz and it reaches 85c with LinX and Megahalems revB with CM Excalibur x1.
So basiclly good look with that kind of voltage.
So what was it.
Is 1.9BIOS not OK. and you are going back to 1.8 ?
As I said on the previous post, I couldn't actually make the temp down to 85c but I got it down to 87c with 1600 Ram speed.
But I got to 5.0 with 1866, though.
I ran HCI memtest and tested all Ram. (7GB+)
Also showing other voltage settings on the screenshots.
This is ONLY 1hour of Prime95 Blend test btw.
But as you can see... there is still NO WAY to run IBT nor LinX w/AVX....
It'll probably give me :explode2: in 4 sec.... -_-
i5 5.0 @ 1.464(Load) 1866 9-10-9-28 1T @ 1.650
Max temp @ 92c :shock2:
http://preview.filesonic.com/img/27/....thumbnail.jpghttp://preview.filesonic.com/img/0d/....thumbnail.jpghttp://preview.filesonic.com/img/f9/....thumbnail.jpg
I got my RAM to run 1600 stable with a bit lower voltage and temp.
Of course it's still hot but I'm NOT even thinking about running this 24/7...
i5 5.0@ 1.464(Load) 1600 8-8-8-24 1T @ 1.620
Max temp @ 87c :eh:
http://preview.filesonic.com/img/f9/....thumbnail.jpghttp://preview.filesonic.com/img/51/....thumbnail.jpg
I don't think you need 1,832V on CPU PLL Voltage. Default value on ASRock mobos is too much. 1,709V will be ok as it has no reall impact on CPU stability even way above 5GHz.
BR,
I thought so in the first place.
But No. I NEED 1.832V. I've tested every voltage setting and this is the lowest that I can put on all the voltages.
(I've tested many times I'm 100% positive about this.)
I've noted before but somehow this board (or my particular chip) needs 1.832 and even one notch below gives me BSOD (above 4.8GHz)
Lots of other MB set up, and people even put it at 1.709v (in fact, at 4.6 w/1600 RAM, I can set it at 1.709) and won't affect the stability but mine does affect big time.
Every system works differently I guess.
Anyway, it is surprising that my 5 year old 4 rail x 18 amps 700w OCZ PSU still works like a charm with modern set up.
As long as I keep it single GPU, 700W is enough I guess even with 8 fans and 4HDD.
Tunagoblin,
I would really appreciate if you could share your UEFI settings for 4,8 and 5,0 ghz
I've tried many different combinations of settings and I can't get any real stability past 4,5 ghz.
As we all know, no systems work the same way.
So they are going to be just the reference.
Even though I can get to 5.0, it's just for the sake of "It can get there."
So by any means, this isn't for realistic use for me since it gets too hot.
4.8 is stable with HCI memtest, LinX (All, 3mb 20+ runs), Prime95 (22hours).
Also I manually put "additional turbo voltage" to +0.004.
It compensates for vdrop and voltage won't keep moving around or going higher like when it's set to "Auto".
Seems like this and LLC @ level2 is working well together for my system.
It makes the idle voltage higher since I'm on fixed voltage.
Also the additional turbo voltage makes the idle voltage a bit higher.
Which actually prevents getting too much of vdroop when intensive load.
But at the same time, LLC is there to prevent any unwanted voltage spike damaging the chip.
So finding the good combination I guess...
As for the CPU advanced setting and RAM timings setting, both 4.8 and 5.0 are the same so I only put 1 of each.
Attachment 118069
RAM Settings
Attachment 118066
Attachment 118067
4.8GHz @ 1.385 (UEFI) 1.384 (Load)
1866 9-10-9-28 1T @ 1.575 (1.560 in the pic but I need 1.575)
Attachment 118070
Attachment 118071
Attachment 118072
5.0GHz @ 1.470 (UEFI) 1.464 (Load)
Attachment 118074
Attachment 118075
Attachment 118068
These are mine 5GHz settings:
http://minus.com/mvbFnm7
Chips are doing very well under water.
Mine's now under Thermochill 240 with 2xGT1850 fans pull
And it's doing fine @5GHz 1.44v for security (1.425 stable ... but for an hour or so) an it reaches 65 max with AVX
Soon screenshots... as my HDD got stolen from my girlfriend for her project... so the PC is not functioning right now except for Ubuntu tests :)
Will test soon more.
Got my patriots from default 1.65v down to 1.5v with tighten timings 9-10-9-24... yes :)
A guy from Overclock.net told me my RAM shouldn't need 1.65v to run 1866@5.0GHz.
Since he had the exact same RAM running 1.50v with same timing as mine, 9-10-9-28 1T.
I tried it it 1.50 with same timings and it made HCImemtest.:up:
Also done some LinX run @4.8GHz and gave me constant healthy 130+GFlops on all RAM.
So I guess I was overvolting the RAM....
Now it made my temp go down about 3,4c.:clap:
I'll do Prime run next.
*Sorry...forgot to open the most important tab, Memory tab... but the timings are the same..
http://preview.filesonic.com/img/74/69/f0/2396411.jpg
I know. I've been doing that up to 4.8GHz. Since at 5GHz, as I said on the post, My CPU gets to 98c with LinX w/AVX.
That is why I can't run it at 5.0 :(
I was hoping to make my RAM run lower voltage but Prime95 is giving me problem...
Even all the ram passed fine with HCImemest.
Bringing up VTT one notch gave me worse.
I'm turning up VRAM voltage back up now till I get no BSOD.
see if it's really the RAM giving me BSOD...
Since it passes fine with 1.650v.
You could try relaxing tRRD from 6>7, and tFAW from 28>33. Shouldn't have any noticable performance impact, just help get high RAM clocks stable with lower voltage.
Cool :up:
I'll try that after I'm finding out what the minimum voltage to run this RAM at the timings I have.
It'll be a good comparison.
I guess my RAM is mediocre also.
Some people can run the same RAM at 1866@1.5v@5GHz+.
Gee... I guess I have to get into those other RAM timings....
Thanks Ket!
Update:
So I found that I need at least 1.590 dram voltage to make at least 1hr prime stable.
It made my max temp down 4c :yepp: or say... a bit better than 92c... :(
Now I'll try what Ket told me and see h ow that goes.
http://www.overclock.net/attachments...66-1.590-prime
Try lowering VTT with 1.5v
1.051 probably.
And check that again.
