4core 720 be on LN2
6188mhz
http://valid.canardpc.com/show_oc.php?id=530612
4core 720 be on LN2
6188mhz
CPU Model Used: Phenom II x3 720BE
CPU Full Stepping: 0904EPQW
CPU Frequency: 210 x 16 = 3360mhz
CPU Vcore: 1.488v
NB Frequency: 210 x 10 = 2100mhz
HT Link Frequency: 210 x 8 = 1680mhz
Memory Frequency: 700mhz
Memory Configuration: 2x1GB
Memory Ganged/Unganged: Unganged
Mainboard Model: Biostar TA790GX 128M
Cooling Type: Air, Core Contact Freezer
Windows Vista SP1 x86
this is my first try.... will make more tweaking since this is my first time playing with phenom 2....
yah LN2, where have you been LOL, broke multiple Wr's but posted in the XOC section, was afraid if I posted in amd section tar, feathers pitchforks, bonfires and hanging rope would come out......
http://www.xtremesystems.org/forums/...d.php?t=221674
been out on a lake all week and only once in a wile I would get wireless reception on my lappy so just now getting cought up on things. Grats on that tho :up:
New suicide for me:
Cold air, 3.85 GHz (203x19), 1x2GB RAM
First WC with new to me 940BE.
Pretty much everything is default settings except for memory 2.05 and volts to 1.45v.
I have to learn to cram all the screens close together so I can crop better to get the thumbnail size within limits :yepp:
This guy can got much more, I am sure, considering I just went straight to this OC.
I wonder if the list will ever be updated...
If you have a legitimate clock that meets the qualifications, send a PM to "particle" with the message number, he'll update the list for you...
That being said... Heres my best CineBench run, I'm not saying it's worthy of the list, but CineBench is one of the hardest to get stable and this is a pretty good score! :D
http://i30.photobucket.com/albums/c3..._cinebench.png
Still playing with multipliers.:D
940 BE
CACVC AC 0849APMW
3808mhz
1,525v
1803mhz
1803mhz
400mhz
4X1GB
Unganged
Gigabyte GA-MA790GP-DS4H
Watercooling
XP x86
http://img257.imageshack.us/img257/5...ct3800mhzi.jpg
Watercooling is not the best. Thermochill PA120.3 combined with TT BW 745 Pump+Reservoir and the TT Cpu waterblock.:D Room temperature 23c
Latest Max OC - not OCCT stable:
Phenom II X4 940 Black
0850CPBW 80243
3900mhz
1.5v
NB = 2400
HT = 2200
1066mhz DDR2-8500
Memory Configuration 2x2gb
Memory Ganged
DFI LP DK 790FXB-M2RS 3/10/09
Watercooled
Windows 7 x64 beta
http://valid.canardpc.com/show_oc.php?id=531724
CODE: 0906 EPMW
stock cooler
please check the pictures for my oc details.
Ok this is my first attempt at overclocking this system since I got it. The system is listed in my sigtag.
System Cooling: stock
CPU cooling: push/pull air.
FSB Freq: 272
Dram Freq: 1440
CPU/NB Freq: 2700
HT Link spd: 2160
CPU volt: 1.4s
CPU/NB Volt: 1.4
CPU VDDA: Auto
Dram volt: 1.7
HT Volt: 1.28
NB Volt: 1.28
I did not touch the memory at all.
Just to preface all of this. I am a very new overclocker, and this is my first real attempt at this. So any advice would be gratefully accepted.
Well I just got done with OCCT and during the process, the CPU temp increased to 51c. I probably get that lower, but it is a pain to remove the case from the cabinet.
Here is mine (CPU NB @ 1.25v)-->>
http://i27.photobucket.com/albums/c1...04-09_147v.jpg
Core temps idle = 33c
Core temps load (linpack) = 50c
Core temps load (linpack) = 50c[/QUOTE]
Xerran, what is your RAMs? And how much modules? I have your MB and waiting at x4 955 BE and must buy any 1066MHz RAM. I heard, with 4 modules 1066MHz can be troubles:confused:...Thx
DFI LANPARTY DK 790FXB-M3H5 + Phenom II 945 HDX945FBK4DGI
http://valid.canardpc.com/cache/banner/550368.png
CPU cooling: Noctua NH-U12P SE1366 CPU Cooler with a Am2/AM3 mounting kit.
HTT Freq: 240
Dram Freq: 1,279
CPU/NB Freq: 2,160
HT Link spd: 1,800
CPU volt: 1.35+ 125mv = 1.475v Bios
CPU/NB Volt: n?A
Dram volt: 1.635v
Ram: 2x2GB
Benches
http://www.images.clunk.org.uk//revi...66_bench_s.png
1st sub 20 Minute Super Pi 32M:)
Stability
http://www.images.clunk.org.uk//revi...66_prime-s.png
For full Bios settings etc., see DFI LANPARTY DK 790FXB-M3H5 3.6Ghz
here is my setup,
8gb ddr1066 corsair dominator
m4a79 deluxe
PhII 940BE coreV 1.4875v
so far my best is 3500 4 hour prime blend stable
NB 2600mhz/ht 2000mhz
http://www.freeimagehosting.net/uplo...7d0ac769c6.jpg
nope havent tried lowering the NB lol ill have to try that
im sure this has been asked before but, what is the highest 24/7 voltage recommended for the PII 940BE?
also running my nb lower than 2600 dosent help my clock speed what am i missing guys?
mobo:M4A79 deluxe
cpu vcore : 1.475 (1.52v in Everest)
cpu vdda 2.60v
cpu/nb 1.2675v
dram 2.1
ht (auto)
nbV 1.22v
nb 1.8 (auto)
sb 1.22v
my NB is 2600mhz, my HT is 2000, and my ram is 1066 corsair dominator, i turned off the "secure virtual machine" , C&Q, i tried the ACC on and off didnt help. i have water cooling triple 120 with an EK block. temps run about 110F full load.
amd themselves specified 1.55v as the max for high end aircooling if i recall rightly.
<1.5v should be fine anyway - ive not seen many amd cores killed with volts, a few imc's by excessive ram volts but thats usually been fixed in later revisions (eg original clawhammer cores)
