tnx man ;)Quote:
On a DFI P35. Still, nice result.
your tg pc6400 has gkx or gmh chip?
tnx man ;)Quote:
On P45 (not a DFI) you will need around 540 FSB to break 11K read without using a high CPU clock to 'cheat'.
You can see in the SS below I am close to 11K at 533 FSB, but to get the FSB any higher I had to back off some chipset settings so I lost some efficiency, which means I had to go up to 540 FSB (shown on second SS) to break 11K.
http://i720.photobucket.com/albums/w...edCTstrong.jpg
Here is a run that is the lowest settings I can use to break 11K read. I use a low CPU clock of 3.78GHz so it just shows the raw power of the FSB and ram speed.
http://i720.photobucket.com/albums/w...MHz11Kread.jpg
i'll try your same settings cryptic, just to verify if it's true that m2f sux at speed against ud3r p45. i've heard about it but i never verified :)
the new ep45 extreme is here :D
go for extreme oc man, i'm waiting screens...will it be pwnage? :D
this afternoon i tried the crucial ballistix of my friend Guglio on my new ep45 extreme. :yepp:
this ram is spectacular...
1400mhz cas5 2.4volt
http://www.pctunerup.com/up/results/..._screen010.jpg
1200 cas4 2.4volt
http://www.pctunerup.com/up/results/..._screen011.jpg
1225 cas4 2.45 volt
http://www.pctunerup.com/up/results/..._screen012.jpg
well done :clap:
but...no more than 1400 cas5? do you try 2.5+v? :D
@Mafio good start.....now overclock the ram :)
This is my new Patriot kit on 2.06V real:
Pulled these from and old HP Media Center PC. Loving them allready. I know they will go higher but I cant seem to get my DFI BloodIron P35 board to do it.It craps out past 1150 dual channel. I must not being doing something right.
DDR2 1100 Cas5 @ 2.0v
JEDEC PCB probably holding you back.
I dont think its that because I have a pair of OCZ Reaper 1150s that will do 1150 single channel but not dual channel. I think its the auto timings the board giving it but im not sure what sub timings to change to give stability. Or I'm just bad with ram lol.
I've run some D9's up to 1350 CAS 5 in dual channel on Blood Iron, for what its worth.
Ballistix Tracers, double sided. 2.35v 1300Mhz. I believe this pair is GKX, but I'm not sure. The don't like T1 and cas 3, but they scream with cas 4 and 5. ICs just say 'Ballistix' and '-f17' Not totaly stable at 1300. Can run SuperPi and other benchies but crap in RL gaming.
http://valid.canardpc.com/show_oc.php?id=519358
rotfl! hp building ht pc with high end ram...incredible :)Quote:
cellshock pc8000 + crucial ballistix pc8500 on my ep45 extreme
1200mhz cas4 @2.4volt ;)
http://forum.hwproject.net/imagehost...15bd6221a3.jpg
guys, this mobo kick ass :yepp:
great job mafio.
