what a pity. probably the gigabyte p45 extreme is ht best p45 board imo.
still waiting for the board to come back...clock it to death man ;)
Well thats very nice ram in that case. The only board i have used that has a real voltage = set voltage is my M2F. Nice to see gigabyte have the same thing I'm getting fed up with boards over/under shooting set voltages.
Pity it died, I hope your replacement goes well. Was the bios damaged in a flashing procedure or did it just die of its own accord?
just a question: to reach high freq (doesn't mean cas latency, but obviously is cas5 or more) which of these is better?
kit pc9200/higher with gkx or pc8500/9200 with gmh?
dunno why, but i've no so much feeling with gkx...maybe the new ud3r could help...
it's not you, it's your board :P
at high freq i think it all depends on how good are ram instead of board :)
http://img165.imageshack.us/img165/1875/10433.jpg
Managed this with my Team Xtreem D9GMH, any suggestions to get them over 11k read? Its what I'm aiming for.
set cas5 and increase the fsb :yepp:
edit: 1300 cas4 with what vdim???
3 char
which is your kit? pc10400? on which board? let me know i'm really curious.Quote:
to reach and overcome 11k read you have to increase fsb. at least 550+ ;)
i've done 11k with dfi p35 ut and ram 1200 cas4 with fsb 600 :D
PC6400C4/P5Q-Dlx AFAIK
@chaps: 11K+ :D, cellshock pc8000 cas4
http://forum.hwproject.net/imagehost...aeaf8ab096.jpg
Seems I scored again, testing my new Patriot 8500 5-5-5-9 D9GKX kit and it seems to only need 2.08V or so for 600MHz C5.
OJ0 was Right, Team Xtreem PC2-6400C4 on a P5Q Deluxe.
This set hates cas 5, cant even get 1300 5-5-5-5, but can do 1300 4-4-4-3 @ 2.66v.
On a DFI P35. ;) Still, nice result.Quote:
@chaps: 11K+ , cellshock pc8000 cas4
If i use higher FSB my bandwidth decreases, can only run PL9 at 550+. Will test over 500 PL8 later today and see where that takes me. :)Quote:
i need high fsb for 11k
i can do it around 508fsb you will need around 520-530 on p45
Anyone know if theres a bandwidth record for P45 chipsets?
on dfi ut p35 i only need 505fsb to hit 11k;)
I have the exact same issue with my TXs. I've suicided 600MHz C3 but can't do 668MHz C5. These sticks are rated at C4 and that seems to be where they're happiest.
Funny enough, my sticks used to be able to do 1333 C5 when Goddy had them, @ 2.44v though. :(
Maybe its just the P5Q Deluxe i have that doesn't like my Rams.
