Yes i get the same message to but i only have one keyboard and one mouse like yourself, i have ask my friend to check as well and post oh the thread...
day
Max temps are now :- CPU 59, N/B 41, S/B 53 . (Quoted running HyperPi on 4 cores)
The fans on my radiator are running at 9.5v so slightly below max rpm for kinder sound levels. Core 1 (counting 0-3) runs about 10 degrees lower than the others which is odd - anyone alse have this ?.
Running an Enzotech CNB-S1L on the S/B and just wondering what temps people are getting with the version with the fan the SLF-1 ?. Drilled holes in the motherboard tray to make this an easy swap if it runs a few degrees cooler.
Greetings, I have a new PC and I need help to get my overclock more stable!
I’ve run Prime95 for an hour and a half several times and everything is ok.
I’ve run OCTT many times and also 3Dmark and apparently all ok.
So, apparently it looks like I have a stable overclock but I don’t… because sometimes I restart my PC and when Windows begins to open it shows a blue screen and it restarts again. And sometimes when I’m working with windows, like, installing some program suddenly the screen turns blue again and restarts the pC.:(
I’m going to leave here the frame of my PC components and the bios settings of my PC:
QX9650
Asus Rampage Extreme
4x1GB CELLSHOCK PC3-15000 MICRON 8-8-8-16
SAPPHIRE HD 4870 X2 2048 MB GDDR5
Settings da bios do overclock Rampage Extreme 0701 Bios:
AI OVERCLOCK TUNER -------------------------MANUAL
OC FROM CPU LEVEL---------------------------AUTO
OC FROM MEMORY LEVEL UP---------------------AUTO
FSB FREQUENCY ------------------------------450
CPU RATIO SETTING --------------------------09
CPU CONFIGURATION
CPU CLOCK SKEW------------------------------AUTO
NB CLOCK SKEW ------------------------------AUTO
FSB STRAP TO NORTH BRIDGE-------------------333
PCIE FREQUENCY------------------------------101
DRAM FREQUENCY -----------------------------1801
DRAM COMAND RATE----------------------------2N
DRAM TIMING CONTROL-------------------------MANUAL
CAS LATENCY---------------------------------8
RAS TO CAS DELAY----------------------------7
RAS PRE TIME -------------------------------7
RAS ACT TIME--------------------------------20
RAS TO RAS DELAY----------------------------6
REF CYCLE TIME------------------------------82
WRITE RECOVERY TIME-------------------------12
READ TO PRE TIME----------------------------6
READ TO WRITE DELAY S/D---------------------9
WRITE TO READ DELAY S----------------------6
WRITE TO READ DELAY D----------------------6
READ TO READ DELAY S -----------------------4
READ TO READ DELAY D------------------------7
WRITE TO WRITE DELAY S----------------------4
WRITE TO WRITE DELAY D----------------------7
WRITE TO PRE DELAY--------------------------24
READ TO PRE DELAY---------------------------8
PRE TO PRE DELAY----------------------------1
ALL PRE TO ACT DELAY------------------------8
ALL PRE TO REF DELAY------------------------8
DRAM STATIC READ CONTROL--------------------DISABLED
DRAM DYNAMIC WRITE CONTROL------------------DISABLED
DRAM SKEW CONTROL
AI CLOCK TWISTER----------------------------STRONG
AI TRANSACTION BOOSTER----------------------MANUAL
COMMON PERFORMANCE LEVEL -------------------08
PULL-IN OF CHA PH1--------------------------DISABLED
PULL-IN OF CHA PH2--------------------------DISABLED
PULL-IN OF CHB PH1--------------------------DISABLED
PULL-IN OF CHB PH2--------------------------DISABLED
EPU II PHASE CONTROL------------------------AUTO
CPU VOLTAGE---------------------------------1.40625
LOAD-LINE CALIBRATION ----------------------ENABLED
CPU PLL VOLTAGEM----------------------------1.55081
FSB TERMINATION VOLTAGEM--------------------1.40491
CPU GTLVREF 0 ------------------------------60
CPU GTLVRED 1 ------------------------------60
CPU GTLVRED 2 ------------------------------60
CPU GTLVRED 3 ------------------------------60
NB GTLVRED ---------------------------------60
NORTH BRIDGE VOLTAGE------------------------1.55O72
DRAM VOLTAGEM ------------------------------1.98806
NB DDRVREF ---------------------------------AUTO
DDR3 CHANNEL A VREF-------------------------AUTO
DDR3 CHANNEL B VREF-------------------------AUTO
SOUTH BRIDGE 1.5 VOLTAGE--------------------1.55081
SOUTH BRIDGE 1.05 VOLTAGE-------------------1.07364
CPU SPREAD SPRECTRUM -----------------------DISABLED
PCIE SPREAD SPECTRUM------------------------DISABLED
ADVANCED
CPU CONFIGUTION
CPU RATION SETTING -------------------------09
C1E SUPORT----------------------------------DISABLED
CPU TM FUNCTION ----------------------------DISABLED
MAX CPUID VALUE LIMIT-----------------------DISABLED
VANDERPOOL TECHNOLOGY-----------------------DISABLED
EXECUTE DISABLED BIT------------------------DISABLED
CORE MULTI- PRECESSING----------------------ENABLED
Ps- if there’s someone out there with a PC with the same settings or similar and has the overclock stable, please share your overlock settings and I would appreciate a lot any advice or corrections of settings for stabilizing my overclock.
ran some 3dmarks with 2 4870 cards :D i must say that this board RULES.. only thing that sucks is that my board has a 120 limit with pci-e frequency :(
http://i163.photobucket.com/albums/t...s/01112278.jpg
http://i163.photobucket.com/albums/t...mark346049.jpg
http://i163.photobucket.com/albums/t...s/03100066.jpg
http://i163.photobucket.com/albums/t...os/0538104.jpg
http://i163.photobucket.com/albums/t...os/0626739.jpg
Nice Bench Scores.
Looks like I'm going to bid farewell to this board, after all.
Never could get the hang of 2x2GB RAM on this.
P6T Deluxe or GA-EX58-UD5 look like they are going to be the next board.
Try this
Bios 0601
Extreme Tweaker
Ai Overclock Tuner: Manual
OC From Memory Level Up: Auto
FSB Frequency: 500
CPU Ratio Setting: 8
CPU Configuration
C1E Support: Disabled
CPU TM Function: Disabled
Max CPUID Value Limit: Disabled
Vanderpool Technology: Disabled
Execute Disable Bit: Enabled
Core Multi-Processing: Enabled
CPU Clock Skew: Auto
NB Clock Skew: Auto
FSB Strap to North Bridge: 333
PCIE Frequency: 100
DRAM Frequency: 2000
DRAM Command Rate: 2N
DRAM Timing Control: Manual
1st Information: 8-8-8-18-5-72-12-6
CAS# Latency: 8
RAS# to CAS# Delay: 8
RAS# Pre Time: 8
RAS# ACT Time: 24
Rest : Auto
DRAM Static Read Control: Auto
DRAM Dynamic Write Control: Auto
DRAM Skew Control :
DRAM CMD Skew on Channel A: Auto
DRAM CLK Skew on DIMM A1: Auto
DRAM CLK Skew on DIMM A2: Auto
DRAM CTL Skew on DIMM A1: Auto
DRAM CTL Skew on DIMM A2: Delay 75
DRAM CMD Skew on Channel B: Auto
DRAM CLK Skew on DIMM B1: Auto
DRAM CLK Skew on DIMM B2: Auto
DRAM CTL Skew on DIMM B1: Auto
DRAM CTL Skew on DIMM B2: Delay 50
Ai Clock Twister: Strong
Ai Transaction Booster: Manual
Common Performance Level: 07
Pull-In of CHA PH1: Disabled
Pull-In of CHA PH2: Disabled
Pull-In of CHA PH3: Disabled
Pull-In of CHB PH1: Disabled
Pull-In of CHB PH2: Disabled
Pull-In of CHB PH3: Disabled
EPU II Phase Control: Auto
CPU Voltage: 1.25
Load-Line Calibration: Disabled
CPU PLL Voltage: 1.5
FSB Termination Voltage: 1.12
CPU GTLVerf (0): +40 ( Deafault is 635.. using 667)
CPU GTLVerf (1): Auto( Default is 667.. is if anybody adds think dudes..)
CPU GTLVerf (2): Auto
CPU GTLVerf (3): Auto
NB GTLVerf: Auto ( Default is 64... DONT NEED TO UP THIS. unless u want to lower the clock twister )
North Bridge Voltage: 1.6 (Didn't write the exact value, Everest says 1.66v)
DRAM Voltage: 2.0
NB DDRVref: Auto
DDR3 ChannelA Vref: Auto ( only had to add this on 4x1gb kit)
DDR3 ChannelB Vref: Auto ( as above )
South Bridge 1.5 Voltage: Auto
South Bridge 1.05 Voltage: 1.11339
CPU Spread Spectrum: Disabled
QX9650
CPU CONFIGURATION
DRAM SKEW CONTROL
ADVANCED
CPU CONFIGUTION
Well, I don't think it's too much of a stretch for a dual. It was doing ok at 498 100% stable, so that was pretty good. But I'm seeing very similar bandwidth/latency as I was getting with DDR2 and very similar FSB (maybe 10-20MHz more), so what's the benefit?
My thinking is, sell this board while it's still hot and someone who can really use it and do some benching on it with a 2x1 kit will probably enjoy it.
Now I'll be learning how to OC the new tech :)
Thanks, I'll give it a shot.
0801 looks a lot more samsung friendly, 0601 was a nightmare for me, i skipped the next build and started testing with the 08 and its doing things 0601 just would not allow.
Its actually starting to feel like the P5E3 Premium now ;)
Sounds positive:)Quote:
RLM
[QUOTE=Maximusss2008;3425941]Greetings, I have a new PC and I need help to get my overclock more stable!
So, apparently it looks like I have a stable overclock but I don’t… because sometimes I restart my PC and when Windows begins to open it shows a blue screen and it restarts again. And sometimes when I’m working with windows, like, installing some program suddenly the screen turns blue again and restarts the pC.QUOTE]
Dude; have a look a few pages back at Eternal Fantasy's settings. I believe he is running a Quad with 4x1 ram. He got my 4x1 Cellshocks stable at 1800. I played with them a while after that but 1800 was it, I went back to 2x1 as it was too much fun. Might have another go later on with 4x1 but sorry, rather busy right now.
Hope this helps,
GriZ
bios 0801 is best for my ,now run stable crucial ballistix tracer 2x2 1600
[QUOTE=Expat GriZ;3426976]well i have something a bit different
using 4x1gb Team Xtreem PC3-15000's with a e8600 so similar
problem is it hangs once in a while...
well back to skewing again..
still find the best way after being confident on ure system is stable is to run crysis... for mem..
Hi Ghostleader,
What part number are your dominators and what speed/timings can you achieve with 0403 ?.
I'm persevering with 0801 but finding that my previous settings do not work so it will take some time.
For those that do not like the pulsating ROG and start buttons these can be switched off in 0801 - Hurrah !!
found something interesting today
and y it always hang
first was for the use of 4dimms i had to clock the pll to 1.57v for 500fsb
second the sb voltage has to be = pll..
geee back to the 975 days..
I, to my annoyance, found that the Noctua C12P HSF, despite the fact it's listed on their site as compatible, will NOT fit in the Rampage Extreme board. The brackets which are positioned top and bottom of the CPU, the top bracket hits the 1R0 devices and will not fit around them. The bracket does touch the gray block devices and I can fit the screws in the holes, but I'm frigthened to tighten them up incase I crush a motherboard component.
Just curous, what HSFs are people using with this board?
Thanks.
Hi aln688,
using U12P here - same brackets as yours? Just enough clearance on mine :D
http://i447.photobucket.com/albums/q...URES/NocB1.jpg
http://i447.photobucket.com/albums/q...URES/NocB2.jpg
Ah, you use your brackets the other way around, for pipe vertical usage. I'm trying to get pipe horiztonal usage. If I position my brackets the same as yours, it will fit and I can screw them in, but, the only recommended orientation for the HSF is the pipes at the bottom, which is fine, except one side of the HSF will hit my PSU.
The other orientation with the pipes at the top isn't recommended. If you still have yours out the case, and you don't have a CPU installed, try installing your bracket, carefully the other orientation, i.e. brackets top and bottom of the CPU, looking at the board as installed in a case, they won't fit.
It bloody annoys me as I spent the good part of a few hours removing the HPA on this board, repasting the NB and SB with Noctua NT-H1, carefully screwing everything together, now the damn heatsink won't fit. One direction the bracket won't screw in over the gray 1R0 devices, the other way the bracket fits but the HSF hits my PSU.
Ugh.
To post images here, do I need my own hosting? I've taken a picture of the bracket but can't get the image uploaded.
Right, after signing up for Photobucket, here goes:
http://i442.photobucket.com/albums/q...s/IMG_3355.jpg
..and another one...
http://i442.photobucket.com/albums/q...s/IMG_3357.jpg
I think the solution is to buy the U12P heatsink, that way I could put the brackets the same as you and don't have to worry about the cooler overhanging the top of the board hitting my PSU.
It's annoying as Noctua lists the C12P as compatible with the Rampage Extreme, so I spent $70 to buy it and now find it won't install. Sure I can fit it with the pipes vertically but as I said, it overhangs and hits the PSU.
Weird thing happened to me yesterday but I figure its from the bios flashback feature or something but I flashed bios from 0404 to 0501 and everything is great improved vdroop control like way improved and got my memory higher clocked at 1800mhz perfectly stable I powered down the machine and back on again bios was set to 0404 I had flashed it 4 days ago I just flashed it back but didnt understand what cause it the settings were running 24/7 for the last 4 days so the bios shouldnt have had any issues
The Noctua NH-C12P actually fits perfect, not touching anything around it.
http://e.imagehost.org/t/0993/Noctua..._Extreme_2.jpg http://e.imagehost.org/t/0337/Noctua..._Extreme_1.jpg
