The reason behind the COLD boot problem!?
Guys, I believe I have found out why we are having a cold boot problem.
I posted this over at OCZ forums:
http://www.bleedinedge.com/forum/sho...9515#post89515
Working scenario:
Basically when you shutdown your PC and power it up again, Vdimm moves up from 0V to the voltage you set it to in the BIOS. (Measured with a multimeter).
Failing scenario:
HOWEVER, if you pull out the power plug, reinsert the plug, DO NOT switch on the PC yet. Hmmm, what is that 2.7V doing on Vdimm?? Switch on the PC hmmmm, still 2.7V? And of course you now have the cold boot problem. The Vdimm never reaches the value I have set in the BIOS.
