right, but we are only speculating, as always :) (hard time waiting some months :-) ). Interesting is too information about CPU clock 3.5 GHz+.
It should be between 300 and 320mm^2,according to latest module size information. That's smaller than Lisbon.
if 6MB at 45nm is 110mm2, no way 8MB at 32nm is going to be that much larger, if anything i would have expected smaller.
I think it's unlikely that the cores including L2 is smaller than the L3, since the L2 is at 4x2Mb and the L3 is at 8Mb. It would be if you included IMC and other parts in the L3-numbers.
300-320 mm˛ sound unreal for me for 4 module version or it will have 16MB L3.:)
4x30.9 = 123.6 mm˛ for the 4 modules
2 MB L2 = 12.62 mm˛
IMHO 2MB L3 cache needs less area than 2MB L2 but now calculate with that 12.62 mm˛/2MB.
4x12.62 mm˛ = 50.48 mm˛ for the 8MB L3
So the 4 modules and the L3 takes ~174 mm˛. I don't think that the IMC and the HT links need 126-146 mm˛.
...or it has a hidden GPU or few plus modules or anything..:)
L3 is in four 2MB slices:
"An 8MB Level-3 Cache in 32nm SOI with Column-Select Aliasing
An 8MB level 3 cache, composed of 4 independent 2MB subcaches, is built on a 32nm SOI process. It features column-select aliasing to improve area efficiency, supply gating and floating bitlines to reduce leakage power, and centralized redundant row and column blocks to improve yield and testability. The cache operates above 2.4GHz at 1.1V."
The photoshopped die photo suggests that there is a lot of space between modules, NB, L3 subcaches and I/O. I'd say: 300 +/-20 mm^2.
No, I did not. Take a close look at the picture and you see that the altered dies and IMC are really lousy shoops. But the space empty between them don't show these signs.
Why would Globalfoundries put som much effort in shooping these empty spaces that they look real, when they don't care about the rest looks like :banana::banana::banana::banana:?
what about 3.5 Ghz clocks? Do u think guys, its clock without Turbo?
superrugal:SRRY,but your meaning is "bull*hit"...Thuban is total diferent design (BD design is possible as high frequency), have 1.125-1.4V, and do u using ussually 1.5V with air for 24/7 OC...can more than 4 GHz stable. But it is not about voltage, but as said about design chip.
I didn't say, the space is empty ;) There are several options to fill it. Another reason could still be to make the die look bigger. But where to put the HT-PHY and DDR3 pads then?
@Oliverda:
The space is not necessary for a high frequency design. But this could be a reason for the module's sizes (more latches and so).
http://chip-architect.com/news/AMD_Bulldozer.jpg
inverse photoshopping effort...
Regards, Hans
