I'm using the same cooler with this board and used the stock MSI bracket since I didn't want to take the board out of my case. When you took the MSI bracket off and replaced it with the H50 bracket, did you notice any padding on the MSI one? I've removed a couple brackets and don't think I saw any kind of padding, so I doubt that's the reason.
So what happens when you press the power button? Do lights come on, fans turn, or any beeps?
Double check that all your power connections are secure. If that doesn't work you should troubleshoot using this for reference.
There's padding I just checked. I checked my connections and everything is tight. I even thought that maybe I am putting too much pressure on the CPU so I loosened the screws, but that wasn't the problem. I did the troubleshoot guide, tried booting with one stick of RAM 1 video card etc.. and the thing won't POST. (Thanks for the guide though)
the stock base bracket has the rubber pads stuck on the base.
Have you short the bios reset jumpers just at the end of the pci-e display socket, that my just do the job, if not, like MassiveOverkill said, stop wasting time and RMA it back, before the dead line.
By shorting the bios reset jumpers you mean clearing the CMOS right? I just tried it and no luck.
