Heh thanks but I can manage without one. :D
any updates on the dual rad version dimas?
Thanks for the info dimas! When should I be able to place an order?
¿So you are still developing that Benchtable that will include the place for a triple rad and on the other side the holes for a dual/triple rad( don't know which are you considering) ?
If that it's affirmative i will be one of the people who are interested in purchasing one of them :D
Cheers
yes, definitively, it will take around 2 weeks, we will post update in this thread;)
down here, a full PDF manual for Easy V2.5 Complete istallation Guide.
Bench Table Easy V2.5 Manual ITALIAN
english coming later this end of week.
How's it going with retail availability here in Europe?
english manual ready for Easy V2.5
Bench Table Easy V2.5 Manual ENGLISH/AMERICAN
Interestingly, designed for desktop obudowa.ładne finish. It will be for sale?
Dimas, do you have any plans to make a smaller version of the benchtable? I really like the design of the Easy table, but it's a bit too big for me at 440 x 455 mm of desk space. Something about the same size as Danger Den's mini torture rack would be perfect, only with Dimastech design (not made of acrylic).
I think if it has to be for ln2 or air benchers it don't need more than 1 optical but 3 or 4 hdd (as Lunait wrote) ;)
it could be modified version of hard which is (imo) good idea ;)
yeah, it also is good option!
waiting for first sketches from the Dimas ;)
Hey Dimas. I love your bench tables and am considering getting one, but on your website i couldn't figure out how to get a shipping estimate. Any way you could give me a shipping estimate for the easy v2.5, and for the hard v2.5 (separately b/c the overall price of each probably will make my decision for me) to Naperville, IL 60540, USA.
Also, i too am interested to see this mini table.:)
I made a render in Solidworks showing how I imagine it to look:
http://i41.tinypic.com/sq4m7m.jpg
In this render, the bench table is 350 x 300 mm (width x depth). I used a 5.25" support cage only, thinking that you can convert any number of 5.25" slots into 3.5" slots. In the render, I used a hot-swap module to convert two 5.25" into three 3.5", but you get the idea. And there is also an optical drive at the top of the 5.25" cage. What do you think?
looks nice, if you can, please post more photos, would be nice ;) with psu and your ideas about hot swap etc ;) as fast as you can ;)
good idea you had there! I think if there will be one 5.25 and rest will be 3.5 would better because one optical is enough for benchers and 4/5 hdd hmm, 01/am3, 03, 05, 06, vantage. That's how I see it and also, on the left side under cpu will be psu right?
sorry for ot dimas, but we are trying to show our vision of the benchtable for overclockers only ;)
edit
http://img109.imageshack.us/img109/6428/sq4m7mjpg.jpg
ad.1
I think there should hole for 8/4pin power for cpu. space for two plug will be enough (as now all EVGA's boards have it, ASUS REX3)
ad2.
some mounting for fans blow fresh air for the gpus.
Finally i got my head clear and ordered one Bench/Test Table Hard V2.5 Inox! Cant wait to have it.
Nice job Dimas, keep up good work!
Thanks :) Yes, the PSU is located below the CPU, to the right of the 5.25" cage. The idea with only using the 5.25" cage was that Dimastech wouldn't have to make a new cage for a combination of 5.25" and 3.5" slots. But if they're making an entire new benchtable anyway, I guess the new cage would just be a small detail. I'll post some more pictures this evening. Fans for the GPU area could be mounted in a similar way as on the Dimastech Easy benchtable. There are thin slits on either side of the motherboard for that purpose: http://www.techpowerup.com/reviews/D...fanholders.jpg (they're not very visible on the GPU side, but they're there)
The hole for 8/4 pin power is a very good idea. I'll add that and post another render tonight.
EDIT: Sorry for hijacking your thread Dimas - we could have the "mini benchtable" discussion in a separate thread if you want.
