maybe it's your cpu or you set low vtt, if you didn't test it on other memories
good luck :up:
hm today I will test system with 2:10 divider and any other sticks. thank you for response :)
btw: VTT was about 1,35 and 1,45V. I think, this is not small VTT :shrug:
please tell us all your settings and options you set in bios
cooling you are using on cpu
i tested a lot of 860 and 870 and can say +95% of them goes over 3600 uncore with 1.35
if u used 2:12 so you had lower Bclk and lower uncore.
ok, for cpu:
200BCLK
VTT 1,33V (200BCLK rock stable) but tested up to 1,45V
PLL 1,81V
PCH 1,08V
qpi 3600MHz (7200)
DRAM only up to 1,66-1,67V
cooling: water or SS -45° without any change...
for memory:
timing is from the XMP profil, after I was manual set TRFC and dividers...
for 2390MHz on ram is this setting OK, but 2400+ is impossible.
If you put higher vdim with default settings then its all OK ?
Can you try them in other MB?
yes, if I have memory on a default (2,2GHz CL7) then I can set voltage to 1,85V+ and system post without any problems.
I donīt have other mobo :(
MSI set right MEM spd?
i mean you have to try cl +3 = Trcd
example if you want use Cas 7 you have to use 10 like tRCD
best way :
set 2200 7-10-10-27-5-88 1.65 and boot
check Everest timings and write them somewhere, then reboot and set exactly same settings in bios :up:
it's tRRD
try 2:12
I think, this is mobo or CPU but 2400 is impossible for 32M SPI... :mad:
some results with small frequency
2000MHz 6-9-6-24-5-88 1T 1,63V real linx stable
http://img20.imageshack.us/img20/426...624163linx.jpg
2055MHz 6-9-6-24-5-88 1T 1,655V real SPI 32M
http://img709.imageshack.us/img709/3...962416532m.jpg
Thanks hiwa! :)
:clap: Thanks for sharing this. What VTT do you guys set for 2000 CL6 ??
he some nice results there borec :up:
Kentaro
dipend
for
200 Bclk
3600 uncore
2400 mem
i need 1.37 on my 870 and 1.32 on my 860
for 4100 uncore and high bclk with high mem i need 1.50 to 1.60 ;)
My VTT is about 1,35V:)
Courier have tried two days in a row to deliver these sticks to me. Why they can't just call..
Can't wait to fire them up! Seems to be perfect kit for low Cas values.
look like finland courier is same as italy
try them under cold and u will see :D
Thanks for sharing
:)It seems these kits can go lower CAS at high frequency than Ripjaws do.
2000 CL6 with 1.65V looks nice. Is anyone going to try it on X58 platform??
2000 6-9-6-24-88-5 1.62 200 X 19
33 minuts LinX passed
http://forum.nexthardware.com/galler..._screen006.jpg
2050 6-9-6-24-88-5 1.65
11 min Linx passed
http://forum.nexthardware.com/galler..._screen007.jpg
i don't think that linx is a good memory stability tool
Try y-cruncher's stability test or WPrime (WPrime doesn't work for me and it's not as effective, though).
ics of this kit?
Iīdont know..
are renamed.
Iīve posted foto of ICS on this thread;)
