This is great stuff. Giving me some idea for my setup, I think am going to "steal" that pump/rez mounting system :D
Well on the triple on the front (which is a sort of P/P with the fans on the door), there's the loop with the CPU and the whole mobo. I get 45°C on an i7 @ 4.1GHz, which imo is good. And for the airflow, with the rad on the floor pushing the air out of the case, I read that it's similar to a "sandwich" configuration of the rads, so less performance. Of course, nice airflow, but with my solution, all the air of the case is extracted, so it results in a depression inside the case, and the air is "sucked" from the outside by some of the ventilation holes. Quite a strange system I know, but that way, there's (I find) less dust inside the case, because there isn't any huge kind of air tunnel going through the whole case. :)
Looking great!
I really like your Res\Pump mounting solution! :up:
Please feel free :) That's why I tried to make this worklog a sort-of tutorial to help others.
Cool, I'm going to bear this in mind. I may just turn the fans round on the door and reverse the fans on the other side of the rad.
I also think it's a good idea using the front rad for the CPU and the other for the GPU. :)
Cheers man :)
Yeah, there's much more space for airflow on the front rad. Anyway, I'm gonna use those Lian Li's wheels, so that it's gonna be a bit more space between the floor and the floor of the case. :)
eponymous-
Have you had a chance to try out that SATA backplane device you got yet?
Been thinking about using one of those too, but then I saw on Newegg there were a bunch of negative reviews saying that Velociraptor drives don't work in it because they apparently changed the design or something and now it doesn't function as well.
I know you said 'with SSDs', but I'm also curious if those have worked Ok in that device or not either.
Thanks!
Awesome work,I have the same case & I love the way your build is going atm... an inspiration to me, Subsribed!
Great build, pulling a few ideas from it for my next one. Your methods are ridiculously overkill tho, but still fun to watch. Looking forward to seeing it progress
Hehe, just got back from vacation. I've still not tried the backplane yet - it's packed away under all the other crap :D
I'm not sure about Velociraptors as I've only read up on SSD's. I'd definitely check before you by though.
Thanks man :)
Hehe, probably a little overkill - fun nonetheless. :)
Now that I'm back expect to see some updates coming soon!
Wow you really got some decent tools for your build.
This build log is great for WC starters! Love it!
Got a question for you:
Which drill mode did you use for cutting those radiator holes?
would hammer drill mode be better?
I have the same case here and am going to try to mount a triple radiator in the bottom of the case just like you did... so thanks for the pictures! :yepp:
Yeah, I like the idea of the radiator on the bottom... the air comes in the bottom and goes through the case that way, and I shouldn't have any filling problems since the the res will be higher than everything else... :up:
Wish it would be that way in my Cosmos S case... the rad is on the top and the res is level with it sticking out of the back... have to tilt up the case to fill it up and get the air out.. :(
Getting the holdsaw at home depot today... :D
Are you going to paint the case?
Let us know how you get on :)
Nah, I don't think it's worth it as I'm happy with the way it looks as is.
Yeah that's right. I'll be pulling air across the radiator out through the bottom of the case.
Hi guys.
I'm going to be fitting my loops together very soon, but before I do I was wanting to ask a question to the community and see what you think:
My NB/SB and MOSFET blocks - should they go in the CPU or GPU loop and why? What's the general consensus these days?
In my opinion, put everything that isnt the CPU in one loop (gpu, mosfet, nb and sb etc) in one loop, and have the other loop dedicated to the CPU only, especially since you basically have the most restrictive CPU block ever concieved, it'll work best in its own loop with nothing else to stand in its way, I have a similar setup so i've messed aroudn with this, otherwise congrtualations on a brilliant looking build so far, good luck and enjoy!
http://img22.imageshack.us/img22/9549/cimg0772j.jpg
very great build.
