Originally Posted by
spdycpu
I can do a 3.2GHz run on my i7 when I get home. It is 10:33am CST now, I should be able to get it run by 5:30pm.
Poke349: I finally got a new waterblock, the Heatkiller 3.0 CU. I can't believe the thing, 4.4GHz is 100% stable (Linx w/ 8 threads for 24 hours). That block with regular water is better than my old Apogee with ice water, no kidding. 65C full load at 4.2GHz, 1.3v. 75C full load at 4.4GHz, 1.38v. I'll give ice water a shot at some point, I really want to get a 4.6GHz run done. It would be nice if you could include some batch benchmarking.
For example you could set 3 loops then specify a range from X to Y. This way I could run 3 loops of each & save the fastest time and test times of 1m, 2m, 4m, 8m, 16m, etc digits as well as the 25, 50, 100, etc. Also outputting the fastest result to a file would be nice as not to need to copy/paste so much text. What do you think?
