cant wait to get mine!
Looks good. Just ordered one today as well. Thanks for posting initial data.
I'll post pics of it when I get my camera back tomorow. It does take up 3 slots. Idle temps:
http://i39.tinypic.com/bgsho4.jpg
The one odd thing is that when you plug in the 8 pin adapter and the 6 pin the ends of those extenders are both 6 pin. Card works fine without issue but still.
what kinds of gains are you suppose to see with this cooler.
Will you still be able to use Catalyst's auto fan speed? Or will you have to set it manually?
Just ordered mine today from SuperBiz.com for 52 shipped, which is a good deal. So I am hoping it will let me overclock some more and get some more Vantage points, maybe let me break the 20000 point barrier, I need another 1500 points to do it.
$45 is more like it.
Can you tell me if it takes 2 slots when you mount it on the VGA card like the stock cooler or do you need to have more space?
Those temps and the sound level are pretty impressive. I'm using Noctua's at 5-7v so I was able to hear my 4870x2 at anything above idle. I'm a bit sad its 3 slots though. I have the room but I fear what will become of my prelude with those 3 fans dumping all that heat onto it.
nsegative have you found your case temps to increase much? ( and i suppose this has alot to do with the size / layout and fan setup ) I'm a tad worried with my TJ07.
looks good ! seems it was worth waiting :p
what about case temp ? as it is not blowing outside, did you see any change ?
Thing is I'm using a reverse atx cm stacker T01. So the fans of the gpu are blowing upwards where there is no hardware but two exhaust fans. Thus my case temp didn't increase a bit (and another thing, even ingame if I put my arm over the fans the air its blowing out is actually relatively cool.
Heck I can even use 100% and it's quieter then stock 35%.
Hey nsegative can we get some picture love please :D
I am surprised at the efficiency though. What thermal poop did you use?
EDIT: why not run OCCT or furmark to see how high you can get the temps ;)
Camera at friends house, hopefully I'll get it back sometime today. The card comes with preapplied and spread MX2.
Furmark. I got kinda bored halfway though..
http://i41.tinypic.com/b9f0ad.jpghttp://i40.tinypic.com/2rw9svs.jpg
Wow gotta give it up for Arctic Cooling they make the best VGA coolers and make it so you don't really need water cooling if you get there xtreme versions.
i hope this thing has a future, its almost too late for 4870x2s but remaking for future cards could be great if people dont mind the space it takes up
I still wish these would have been out closer to launch. It would have made my build all the better. I wouldn't have even considered water at the time as other than the fact these take up 3 slots, they appear to run as well and likely just as quiet as most water setups :up:
Just take the fans off and put a 120mm fan on the side of the card... should be similar temps still and only use 2 slots.
