please consider this, it would make the case functionally the same yet smaller in size - this is always a good thing
Wouldn't mounting the radiator horizontally, and shrinking the case, force you to remove the divider between the motherboard/drive 'chamber' and the top radiator 'chamber' ? This would force them to share heat, and disrupt the straight-through airflow created with the front and back fan. I rather appreciate the idea of the separate chambers that segregate your heat sources.
I do like the idea of at least cutting the holes in the front of the top chamber to allow 5.25" drives to be mounted up there, because it would allow you to put the (already shallow) fan controllers up there and still keep a quad radiator. Most Fan Controllers I have seen aren't more than an inch or two deep as long as you remove the cd-drive-sized tray they come with. I am not sure of the feasibility of putting the necessary mounting brackets up there for the 5.25" drives though... as they would prevent a quad-rad from ever being installed properly, and block the airflow to the fans. Also this would add even more to the cost of the case... I'd say this is a bit of a toss-up... cost vs more 5.25" bays... I'd still prefer the cheaper case, but I do understand how others would appreciate the bays.
Once you stack shrouds and fans on the radiator, you would end up with the same height compartment just to sneak some air into the fan.
Add another mark for people who would buy this if available.
If the price could be kept under the $400USD area I would seriously consider picking one up as soon as they are available. I do think however that only 1 optical drive bay is required, 2 is probably safer for other's needs.
^ likewise if I decide to delve into water cooling :rolleyes:
Yeah, I actually use 2, but I put my fan controller in backwards so I don't need to see the ugly display on the front of my case.
I just hope this guy can possibly get it fabbed, cause I am now very interested in getting something like this. With screw slots not holes so it can accommodate any rads of course.
I have designed it to have a single 480 at the top and a single 360 at the bottom, but there is plenty of room for double that if you were to go for a stacked rad configuration.
I have been thinking about adding one or two 5.25 bays at the top. Now that I have extended the depth of the case, it would be possible to have a couple of shallow bays for a display or fan controller, but not drives and still have room for the 480 rad.
Adding another PCI slot would not be a problem as I have extended the height of the case to allow more room around the motherboard.
As I've said before, this case has been designed for liquid cooling not as a server case. With the huge capacity of HDD's these days, I'm sure 4 is adequate.
Thanks for all your ideas. Just like to point out that, as far as I know (correct me if I'm wrong), the fan on a PSU blows air into the PSU enclosure and vents out of the back. This is why there is a hole above the PSU, to improve air flow through the case, so yes; you would mount your PSU with the fan pointing up. Also, although it's not very clear, I have designed the motherboard tray to be removable.
Again, thanks for all your input.....:up:
I'll check when I get home to be 100% certain but I think you are right because dust tends to build-up under the case, which makes sense the way you explain it. In that case (pun not intended), disregard my suggestion for the upside-down psu ;)
Also, the more I think about that case, the more I want it. MAKE IT HAPPEN! :D
Made a few changes/refinements, incorporated some suggestions. What do you think? :cool:
http://i277.photobucket.com/albums/k...se-mkII-20.jpg
way to go.
PD: usb and microphone jacks should be on top (easy access)
What if I put the ports in a 5.25 sized panel and added a shallow 5.25 bay at the bottom. That way you could mount the ports in any of the available bays, top, middle or bottom, or omit them if you preferred. Of course, the case would be supplied with 5.25 blanks to cover any bays that were not being used.....
What are the actual dimensions for the case ? and how big are the chambers ?
jw
Ninja
Just to clarify, the dimensions are:
Width = 230mm
Height = 625mm
Depth = 680mm
The rad chambers are approx. 135mm each, and the main chamber is 345mm.
There is room for a 480 (120.4) rad in the top and a 360 (120.3) rad in the bottom together with a long PSU if required. The motherboard tray will accept an extended ATX if required. The HDD rack will accept 4 drives. There is enough room between the motherboard tray and the HDD rack to fit two pumps and two reservoirs.
Yeah, for those who put their case on the floor, this would be a disaster if someone were to accidentally step on anything plugged into that panel on the bottom.
I think making it modular/customizable is a great idea. Mock it up ! I just hope it doesn't make the case too pricey.
As for other suggestions, I just thought of something...
Would it be possible to move the PSU to one side or the other ? It seems like right next to the PSU would be a great place for pumps/reservoirs/gauges/SSDs/whatever, and the more room available there, the better !
definitely go with the modular idea. Many people use fan controllers or other such panels which have USB/audio support on them already, and it looks silly to double them up. Personally I have no use for them so I would be putting in a blanking plate.
What are the chances of ever being able to own one of these? What steps are being taken to put it into production?
I'd move the hard drives to the bottom, then make a shroud to fit the front fan to a PA160. Do stacked radiators up top like they do in the bottom of TJ07s
You have the buttons on the right side of the top 5.25" bays, why not use the left side for the USB ports? Looks great though.
