Originally Posted by
pershoot
looks like i fixed my idle freeze on my particular cpu (hasn't frozen yet in over 24 hours; but still testing). ACC is now at (top to bottom) +4,+2,+2,+2. try that. i can do 3.2, but having some heat issues, so need to sort that before i bump the volts back up to stay at 3.2GHZ (havent tested the aforementioned acc setting for idle freeze at 3.2 yet, only 3.1). before adjusting acc, set your multiplier back to stock, save, adjust acc, up the multiplier (i noticed some buggy behavior on the bios causing a false alarm no post, so i have been doing it this way...). boot in to windows, shutdown. power up, if you POST, go back in to windows and let it sit there/browse the web, play music, etc. to test idle freezing. i can only post with auto, +2 or +4 (so that's why its best to shutdown and then power up to ensure that you can POST from cold boot; once you play with acc, youll know which values result in a non POST, etc., for you).
flash to 9/19 beta if you haven't done so yet. it helps with stability over the stock bios.
i dont use prime95 anymore, so cant help ya on that front. i have been using occt. works well for me!
good luck:)
