Originally Posted by
Martinm210
Great!
I may be getting a sample to try out too, so I'll hopefully have a chance to do the pressure drop testing.
Oh awesome! Can't wait for that!!
Is D-Tec sending it to you?
If the V2 isn't bowed much, you can always use a slightly thicker o-ring than what comes stock, that should do the bowing fine.
Yea, the V@ isn't bowed at all. If anything it's bowed the wrong way, because when I lay a straight allen wrench on top of the copper theres a very slight gap in the middle....
So I'll definitely try a bigger o-ring.
I'd like to see a V1 with washer only compared to a V2, then maybe a V1 with quad nozzle vs V2 with the Quad midplate.
Is the washer the O-ring or is it something else?
Don't forget some multiple mounts, when I ran my first V1 5 mount test, I was getting almost 2C differences just for different mounts...I'm getting better with mounting though as my nozzled 5 mount run maximum variance was 1C between mounts.
Yep:
I'll be doing multiple remounts for each test to make sure the results are good.
Remounts are definitely important, looking at your chart tells why.
I'm gonna have a lot to do this weekend :D
