Thanks! :toast: I've just found out about this software.
How does one get DX10.1 on server 2k8?
Got a bSOD in Server last night which i never had in VIsta. But im thinking it could be related to Nvidia drivers i am runnning, will test some more tonight.
BAD_POOL_CALLER
how do i actually get to the desktop? it says i have to change the password before logging in, but every password i have tried just tells me it's not complex enough, or long enough, or doesn't match the history of the domain...? what do i do haha
I will post benchmarks later and explain better as for now I can say Win Server 2008 is quite similar to XP, %5 less performance on some tests, some +5%. I have to fix an internal problem with my hardware first, looks like my CPU got a real time flash light bug due to some xtreme overclocking.lol
Metroid.
Temporarily Bypass Windows Server 2008 Activation
http://www.petri.co.il/bypass-window...activation.htm
microsoft is so safe :D
My report on this:
Hi all-
I was swayed by the rave 20% claims as well, and scratched my perfectly good and "legit" Windows XP + SP3 install in favour of W2008 WS edition (evaluation.)
And before you reply to my comments, get this, I am a legit owner of a Vista HP license as well. That box has been lying unused for a long time now :P
I thought the performance in gaming would have taken a good turn.... but alas, no such thing. The FPS is STILL crappy compared to XP in Source Engine games (like CS: Source.) I for now will be moving back to my XP install tonight.
Do you think sp1 for vista is compatible with server 2008 ?
great thanks
Is it faster than XP x64? Should I wipe out my partition to install 08?
I'd say it's most unlikely that 2008 would be faster than XP-64. Comparing Vista to 2008 is probably done in the wrong way, since they don't have the same settings in stock. I'd like to see someone comparing them the same services started, and same features used, maybe both stripped down with the same vLite file.
It's not that hard to figure out which version of Windows 6.1 that is the fastest one out of the box, Vista have a lot of stuff running in the background. I'm sure you guys here know how to turn it off, but not everybody. Comparing with stock settings (except for things you must change in 2008) is not a fair comparsion, even though some people think so.
I install server 2008 coming from xp , I think it's same speed, but I can't find a antivirus that work's with it (x64 edition) ??
Wich one you use ?
NOD32 also works fine.
Use Threatfire. It's free and performs way better than most AV.
well don't know why but I can't install any antivir , always detected as a server OS ( yes I know it is but need an antivir )
http://img230.imageshack.us/img230/5345/antivirbr9.jpg
Of course I take each time x64 compatible
