Roger that!
Spin free zone.
i'll grab some of that e-popcorn...
Also, keep in mind that even if Swiftech claimed to never heard of that many corroded GTX, it's very possible that owners who got corrosion on their GTX/Stealth just silently toss it in the garbage can not knowing there is a warranty and buy a different one. That might add up if we can find out how much of those guys did it.
IIRC, the spec's on each plated layer was .0005 thick, this is not very thick at all. The easiest way for me to describe to everyone how thick that is, is by using the good old human hair analogy. The average human hair (top of head) is approx .003, if you were to slice it length wise into 6 equal strips, it would give you .0005. Both layers of plating would equal 2 of those strips. It wouldn't take very long for "heavy" water to destroy both layers of plating if it were moving close to 1GPM or higher. Heck, they even have CNC's that use water with "proper" abrasives to machine metal.
LOL....Happen to see someones post over at [L]impOCP about this same exact topic.
Anyways, I am glad that we have people willing to sacrifice time and $$ here such as Petra to bring some more "intelligent" insight on this matter. I cannot wait for the results.Quote:
The reason Swiftech released a copper top was because the idiots on XS screamed like banshees and he got tired of listening to their rants.Quote:
That's what backfired here and why Gabe released a copper top recently.
**Edit** I wonder if it was posted by the same waterlogged that posted in this thread? I would hope not.
-yonton228/timmy
Gabe:
U where pretty confident that the plated alu should not be a problem at all and where kinda almost offended of the people who where bashing the alu and wanted copper or delrin instead. U refused to do anything with it as it was fine like it its.
U have released a copper replacement top later, but i feel ur meaning about it is something like: "Its not really needed, its just to satisfy the enthusiast", or something....
I know, it aint many cases of corrosion, but there is SOME! And some could be none if it was delrin instead.
And the longer the loop is running the bigger tha chance of corrosion, right?
Now u say that some additives is necessesary with the top,(is it because of the alu maybe? ;) ) but do u really believe that 2 drops of PTnuke would have elimenated the corrosion? No!
Im not suprised to see this thread and im (still) not touching the gtx. (im getting a fuzion)
Isn't PT-Nuke generally used for preventing things from growing? I believe you meant Pentosin or something along those lines?Quote:
Now u say that some additives is necessesary with the top,(is it because of the alu maybe? ) but do u really believe that 2 drops of PTnuke would have elimenated the corrosion? No!
-yonton228/timmy
PT nuke is and anti algae additive.. But it still is an additive ;)
Edit: And in an all copper loop, thats all u need. Distilled water and a couple of drops of PT nuke...
Seems very simular to a problem i had in my prevuis setup...
Innovatek G-Flow and Fluid XP does'nt mix...
:shock2: WOW! I have a doppelganger. I wonder who I ticked off enough to want to do that? :shrug: Thanks for the heads up.
I don't go out of my way to visit them ([H]) unless a link is posted here. They're simply not worth my time. I have only 2 accounts with this nick, one is here and the other is @ DD, but I've since retired from there as only DD products are to be mentioned when the usual "what parts for my loop" question comes up.
Don't forget the blame the USER that bought it and didn't bother to take any means to minimum the risk of corrosion (actually accelerated it)...... It took two things to happen:
1. Switech to make the product
2. A consumer buying it that doesn't want to read instructions
Funny everyone rushes to the aid of a user that clearly shouldn't have bought the product if he wasn't going to bother reading the instructions or better yet use any common sense. Accountablity is a thing lost in this world.
I'm the first to agree however, make it VERY clear that even though the top is milspec plated, that one MUST RUN ANTI CORROSIVE additives otherwise corrosion will occur, despite the treatment to the aluminum top. In all fairness Rick, your argument would be valid if the top was bare aluminum (which it should at this point be treated as). Shame that Swiftech said corrosion would never be an issue with this top. Wonder why they said that way back when, and now they are saying, 'Well, sure it will corrode with just distilled/tap water'.
I have been running my loop with all copper, except for the mixed GTX for about 4 months now, I have PT NUKE and Pentosin G11 in the loop. I will have to take down my loop and check out my block, to see if there is any change, if there is I will post pics. My system runs 24/7 so the blocks get a decent amount of abuse.
As is, I have 4 blocks in my loop, GTX, 2XMCW60, MCW30, as well as the Copper PA120.3, so in theory, there SHOULD be corrosion, but if not, what does that say?
The only thing I want is some assurance that my block won't corrode and after talking to Petra, and it being discussed that I have a corrosion inhibitor in the loop that I should be okay. I can not begin to count how many times, I have seen others state to use more then just water, because of the potential for trouble.
If someone doesn't follow well stated advice that is the fools fault, we all come here to XS for the information and its clearly stated time and time again.
Gabe, Petra, and Niksub i would wager to say have a pretty good idea of what they are talking about as many of us have waged bets with our money in buying from/through/because of them and others. If this were a bubble and it wereto collapse because of a simple oversight, no one is to blame as its all our faults, so we are all to blame.
All this finger pointing and bickering is childish we are not in the school yard arguing over if someone was out playing kickball.
Please explain?
Yeah, I remember some of the members from this forum preaching on [H] that it was "milspec" material, blah blah blah.
Now for a company to make a BOLD statement that corrosion would never be an issue is plain dumb. I did not see that comment.
I will however stand by my comment that I would NEVER use a product that bolts aluminum directly to copper.
AMEN to that Phelan...
